14" Rockford band saw
johnnyo
johnnyo
I acquired a 14" Rockford bandsaw. The upper blade guide is broken, & needs new tires for the 3 wheels. Can anyone please help in finding parts for this saw. Would Delta or Rockwell parts fit?
thanks in advance.
Re: 14" Rockford band saw
Gerry in North Surrey
That saw looks like a dead ringer for a Busy Bee (Grizzly Tools in the US) saw that I used years ago. If memory serves they discontinued that model because of a blade breakage issue. Give them a shot, they may have parts. I never had a blade breakage issue after I switched to brand name quality blades. Good Luck with your search, I had years of reliable service from my little three wheeler.
Gerry, who's now got a 1948 model General languishing in storage.
johnnyo
johnnyo
Thanks Gerry, do you remember what size blades you used on it.?? The saw runs nice & quiet, & I sure hate to scrap it..
My memory isn't good enough to be able to remember blade size. I think I got rid of the saw in the mid 90's. The saw did have it's limitations, resawing was out of the question, as was any kind of heavier work. I used mine for 1/2" (or less) softwoods and sheet goods. Cutting was often slow mainly because of the inability to generate any real tension on the blade, you're limited to what the little springs on the top wheel will generate. Now that you've got me thinking about the little saw, 58" seems to stick in my mind but don't go ordering 58" blades on my say so, my memory is excellent but short.
Gerry
johnnyo
johnnyo
Thanks for your reply.. & thanks for your previous mention about Busy Bee.. I phoned Busy Bee in Edmonton, & they emailed me a manual, & the parts are all the same.. He remembers Rockford & said all parts will fit, & he has all parts in stock & will ship them to me..
Appreciate all your help, & I thought all was lost.. He did mention that it's best to cut at slower speeds, because they were notorious for breaking blades & did say that it's best to cut slower.. & he has a blade for it..
John
James Hisebert
If you need new tires, try this site:http://bandsawparts.com
Btw, I get good quality blades from another site: http://sawblade.com.
Hope this helps!
Jim Hoeller
I was given a Vaughn meat cutting band saw that had been converted to wood cutting. The wheels are an odd size and I could not find bandsaw tires that fit. Fortunately a shop teacher and a member of the St Louis Woodworker's Guild suggested that if the wheels had a crown, bicycle inner tubes cut in strips would work. Or, in a pinch, duct tape. The bicycle inner tubes have worked well.
James Hisebert
I’ve heard that cool idea somewhere in another forum site. Someone told me it worked out. I wonder how long will bicycle inner tubes last?
johnnyo
johnnyo
Thanks for the link for blades.. Gerry had said once he got a better quality blade he didn't have much breakage problems.. I will try them..
And thank you much for the bicycle tube hint.. I never thought of that.. Guess my old brain is getting tired.. Looks like I may be able to salvage the old saw after all, thanks to everybody's help.. I'm going to be 79 soon, & hopefully this saw will serve me for hobby work.. Now just to get it tracking well after the parts arrive.. Thanks again for all the tips & links..
John
johnnyo
johnnyo
haha at the rate things are changing, it's just a matter of time somebody comes up with a solid soft tire that won't need tubes nor air... hmmm, now that got me to thinking... :D
James Hisebert
John, those blades are tested. I have used them for quite some time. And they always tell me to observe the proper break-in procedure to avoid the teeth of the blade from dulling fast. And they last long, for sure. I also like their customer service, specially how the sales reps answer phone calls. I would like to recommend you a direct line where I usually call: (201)450-9810.
johnnyo
johnnyo
Thaks James.. I will give them a call once I find out the size of them.. Plus Busy Bee only have the one width, & I think that's one reason they would break, especiall cuttin tight circles.. I used to use thin blades (1/4") for doing gircular work & they lasted much longer. I tried cutting a circle of small dia. & it was a total catastrophe with a 1/2" wide blade.. But then again I'm not an expert craftsman... hmm come to think of it I'm probably not a craftsman of any caliber, but I love working with wood.. Picked up a small lathe, but it doesn't have a plate on the outside to screw a bowl block on to work with it.. Looks like a better lathe is in the order for Santa..
best band saw blades
del schisler
The are the best blades call them with the blade dia and they will get the blade for you. I use these for resaw and have use other blades but these are the best so far the link
and a good video to watch also the link
http://www.youtube.com/watch?v=wGbZqWac0jU&list=FLYDEiGLzvqQNIl-nqvD2OOQ&feature=mh_lolz
http://www.supercutbandsaw.com/
James Hisebert
No problem, John. Being a craftsman isn’t about having the best caliber, it’s about having the heart in doing the stuff. BTW, this video might help you with cutting tight circles: http://youtu.be/1BdBE9Xp0I4. Have fun!
Jim Hoeller
If you trim the strip carefully and use rubber cement to bond it to the wheel, it will last (so far about 2 years). If the edges of the rubber strip are not smooth, a tooth of the blade can catch it and off it goes. It took a few tries to get it right.
