OT Siding Problem
OT Siding Problem
OT  Siding Problem
AZ in Colorado Springs
A friend recently purchased a foreclosed home. This past weekend we took the deck down, and it was in really bad shape. Going across it felt like walking on a sponge. No footers for the posts, just 4x4s sunk into the ground. Don't know how deep the 4x4s went, as they broke off at ground level during the demolition (and we were not trying to remove the posts).
So, there was no flashing atop the ledger, and the ledger itself was bolted to the rim board on top of the lowest piece of siding. Fortunately, the rim board is intact, but the two lowest pieces (rows) of siding are completely ruined from water infiltration, and the vertical trim board at the corner of the house has a rotten section where it was in contact with the deck.
I have not pulled off all the damaged siding, as I don't want to expose that portion of the structure to the elements, any more than it already is, until I'm ready (with materials on hand) to close it back up again.
So, here is my dilemma. It seems as though there is some sort of felt layer under the siding (this house was built in 1988). What is that called (so I can purchase the right material)? After I remove the two lower rows of siding, how do I attach that replacement material to the sheathing? Lastly, how do I tuck that new material under the old/original material under the siding above? Is there a trick to it? I know it needs to overlap properly to prevent moisture from flowing toward the sheathing. How much overlap is required? Will I need to remove and then reinstall an extra row of siding?
Any advice you can provide will be greatly appreciated!
Andy
Re: OT Siding Problem
Dick Coers
My daughter almost bought a house with the exact same issue. I was there the same day as the house inspector. I noticed no flashing, took out my pocket knife, and buried the blade into the house. No resistance at all. Rim joist was rotted, ends of floor joists were rotted, sheeting was rotten. I would be surprised that you won't find more damage once you take off the siding. What type of siding? You will find the width and exposure once you start taking it off. Many houses were built just using tar paper under the siding, and face nailing is pretty common. You can get under the siding and cut the nails using a long nail cutting blade on a recip saw if prying the old nails out creates a problem. Use double dipped galvanized or stainless steel nails for the new siding.
I tapped a nail into the rim board so I think that is solid. Haven't looked at the sheathing yet, though. The house is already bought, so I'm helping them work through it.
Keith Newton
Yep, I've run into this problem before too. There is nothing to do but dig until you find solid wood, then work your way back out.
As for the inside corner trim, this is a good excuse to buy a multi-tool, if you don't own one. You can remove enough bad siding from one side, maybe there will be some short pieces between a door and the corner, which will be easy to take off and replace, after you cut out and replace the bottom, already primed and sealant in the joint.
As for new flashing for the new deck. I like to start with about a 2" wide piece of decking against the sheathing, then have a sheet-metal shop bend me a flashing, which goes up the wall about 6 ~ 8", then out on top of the 2" deck board, then down about 1/2" below the top of the joist. I snip both side of the joist, bend it out, and seal under that tab, so no water coming down the wall of falling onto the deck even gets to the end of the joist or band joist.
It is a good idea to even start with about 1/2" space between that first deck run, so the crud which gets into that gap can fall on out. If you prime and paint the flashing the same as the siding, it looks fine.
If you run your flashing under your first deck board, there is no way to clean out the pollen, catkins and dead leaves which become a potting medium for decay even for rot resistant material.
The "felt material," if it's black, is tar paper, although my hardware store calls it roofing felt. Comes in two weights, 15 and 30 pound. 15 pound will be a lot easier to work with in this case.
Ideally, it should overlap two courses of siding; but, if you can work it up under the existing paper for one sound course of siding, that'll be better than nothing.
Remember that the rule is "think like water." You want every action you take to encourage the water to flow out of the building.
Current code, I believe, calls for a gap between the siding and the deck ledger, to prevent exactly this sort of problem. There are commercial spacers for the purpose. That said: proper rot prevention and structural attachment of a deck is a big deal - there's been a lot of damaged houses and injuries from catastrophic deck failures - and many areas require permits. You should look into permits, and you should consider involving a pro.
You have gotten good advice above.
As a Home Inspector I see this situation many times a year. I have literally seen it thousands of times.
The current state of the art is to not attach the deck to the house. If possible, leave about a two inch space between the house and the deck. This will require a second beam closer to the house and that the deck be braced against swaying.
I recently built a deck and I asked the Local Building Official's office if they had anything on what they wanted. They printed out a 29 page document that is a set of instructions on how to build a deck. You might check with your local Building Official.
The "defect" is in the flashing details and that water gets in in tightly enclosed places. Wood has to remain wet for a long time to actually rot.
I have used flashing like the window "tape" you can buy or strips of Ice & Water Shield. They are gooey so that they seal around any nails driven through them. Be absolutely certain the nails, screws, or bolts you use are suitable for use with treated wood, if you use treated wood. Heavily galvanized or stainless.
Thanks for the answers & info
It's already been decided that the next deck will NOT be attached to the house. The current issue is to make a sound repair to the back of the house.
I will contact the building department for information.
Thanks for all the advice.
Jack Guzman from Maine
Re: Thanks for the answers & info
Good advice but one other thing. As far as leaving the underside exposed to the elements,you may have to. I usually remove all damaged siding and protective felt to where I can see if there is any rot underneath. Many times the sheathing is wet. Exposing it lets it dry out before repair. If you are still unsure at this point you may want to involve a carpenter.
I always separate decks from the house.---Jack
tar paper   my guess
