I have to store a contractor style table saw for an indefinite period and it will be in a damp unheated environment. Possibly through the cold weather. I am sure that rust will form on the cast iron top unless I do something. What should I coat the top with?I'm not sure those sprays like boeshield are quite enough under the circumstances. --or are they?---Jack
I's spray it with BoeShield (or a light machine oil, or maybe even PAM, if I couldn't afford the BoeShield), and cover it immediately with stretch-tite, and then throw a tarp or a sheet of corrugated cardboard over it. When it comes out of storage, peel off the plastic wrap and dissolve the protective coating with WD-40. It works on machinery that comes all the way from China.
It's not the cold that will get it, it's the warming up in the spring after being cold. That's what causes the condensation to build on it and stay there. I would use cosmoline.
Cosmoline for sure but it is a lot of money. T-9 Bowshield is the next best but coat it well. Also be sure to treat the trunnions and the worm gears as well, but don’t coat them with cosmoline just use it on the top.
Sounds like the right stuff. Only,I like William's idea better ,it doesn't cost $59 a quart. I only paid $75 for the saw. That's why I need to store it. I have no room for it but I couldn't pass it up at that price.Thanks for your reply.---Jack
I took a pice of rusty metal and sanded part of it to a shine and sprayed LPS3 on it and left it outside in the direct weather in New England and it stayed shiny for over a year. You can get it at Mcmaster and other places. 11 oz spray can is $20
That's why I recommended covering the lube with plastic wrap. Any condensation will sit on the outside surface of the plastic wrap until the temperature of the cast iron rises above the dewpoint, and then the condensation will reevaporate.
I spray all my cast iron tabletops with TopCote. It all sits open to very changeable environments inside my unheated barn in Northern Michigan. No need to add other covers. Cast iron stuff sweats big time in the humidity, but does not rust as long as there's a good coat of this stuff. Makes the tables more slippery when in use, too, so wood slides better.
