I'm getting into wood working and I found a design for a head board my wife wants me to build. The question I have is there any difference in using treated vs untreated wood ? The problem I'm having is finding untreated wood in my local area. Can treated wood be used for making this project ? Apparently several saw mills in my local area have closed down or don't sale their wood unless it's in bulk orders. Any input would be greatly appreciated.
Treated wood is not suitable for furniture. It is usually made from softwoods, it has a high moisture content, it contains chemical salts and does not generally accept a finish.
Click on the Woodfinder icon on the top of the Woodcentral page to locate a hardwood supplier near you.
In my area, Lowes, Home Depot and Menards all offer hardwood lumber aside from their construction lumber.
Either type can be used if both are done correctly. Being new to woodworking, I'd use kiln dried wood from a good source, no since complicating things from the start.
Might trying contacting a cabinet shop to purchase smaller amounts of hardwood or the big boxes sell hardwood lumber.
Don't know that there is a simple answer, as the best kind of wood, depends on several factors: appearance, texture, cost, etc. Most folks starting out will use something like white pine, due to cost and easy of working, although the knots in a lower grade of pine can be a problem. My waterbed headboard was less than a two hour job, used 2x10 softwood framing board, cut the corners off at an angle with a skil saw, routed the show edge, cut some 2x2 to attach from behind the headboard with screws, 25 cent sanding job, slapped on some stain and finish and called it good. I've always suggest to anyone beginning in woodworking to keep it simple and push yourself a little at every new project.
wood finder is under the wood central logo. But you must close the pages down and you will see it. It will now show up when reading post's. try that del
Do you have a way to mill the wood? If you do not then I suggest you go to a Wood Craft store and tell them what you are building and let them guide you.
Have not used it since the 7th grade, made a shoe shine box out of it. Don't remember much about it except for the green colored heart wood. The tree grows straight and there is plenty of them, so the price should be right. Poplar is not native around OK.
