I've got some half inch thicknesses of madrone burl. The burl was old before it was cut and the faces show that nice burl figure, but they are very dark. Has anyone tried oxalic acid to try to brighten/lighten darkened madrone burl?
Oxalic acid will probably not work for this application.
Oxalic acid is more of a chelating agent. It will help bind with metals (iron and the like) and get them out of wood. For instance, if you had an iron stain in oak or the like, the oxalic acid would help with that.
The two part wood bleach with hydrogen peroxide would probably be of more use. You could also try something with regular bleach (sodium hypochlorite) and that might work.
