Stupid Dog Trick *PICs*
William Duffield
This is an instructional repost from an hour ago on Hold Downs from the Hand Tool Forum.
A few years ago, I wrote an article for WoodCentral on versatile hold down clamps.
http://www.woodcentral.com/cgi-bin/readarticle.pl?dir=jigs&file=articles_144.shtml
Mine are Purpleheart, but Woodpeckers and others make hold downs in aluminum that work on the same principal.
Originally, I thought that the best way to use these was to drill half inch holes in the bench top and install threaded inserts. However, threaded inserts are a bit of a pain to install, especially when you might need them all over the place. They also work using T-bolts in T-track, but here the issue is the amount of force you can apply to the screws holding the T-track down.
More recently, I built a meta-bench, with what some have determined to be way too many dog holes. I thought it might be a useful idea to be able to mount stock between dogs on the front of the meta-banch, so I drilled a series of dog holes along the front edge of the top, carefully aligning them with the row of dog holes I had already drilled in the top of the bench. I also put a matching hole in the side of the front vise chop.
If you are a turner, you already have a saddle square like this one. I have three, in different sizes, and I've been toying with the idea of grinding one leg down to 6° so I could use it as a dovetail marking gauge. It would still work with the rule as a center finder.
Be careful how deeply you drill the holes in the side, or you will be drilling and tapping a hole in the end of your dog so you can extract it.
For holding work to the front or top of this bench, I have migrated to using Grammercy holdfasts or a Moxon vise. While hammered-down holdfasts and two wheeled vise jaws are both very effective for holding work to the top or front of a bench, they’re not the only alternative.
After installing the dog holes, the proverbial light bulb turned on, and I implemented this idea. It makes better use of some of the superfluous dog holes.
I drilled a hole in the side of a Veritas Bench Pup, using a v-block, and tapped it to match the threads of my hold downs. 1/4-20 UNC or 5/16-18 UNC both work. These are 5/16".
The dogs can be inserted in either the horizontal or the vertical dog holes.
