Raised panel doors with router
Jerry Holloway
Is it safe to use a second layer on the front of a fence to keep from having to move the fence multiple times when making a raised panel? I am starting to make cabinet doors for my kitchen. I have a router table and a raised paned cutter with a back cutter. The doors are made from alder. I know I have to make multiple passes and I was thinking on setting the fence for the final cut and having several false fronts for the fence of different thicknesses that i could bolt on the front of the fence. I would start with a thick one, make a pass and remove that one and put a thinner one in its place, and make a cut. Do that until the final pass is on the real fence surface. Sounds OK to me but not sure?????
Re: Raised panel doors with router
I don't see why not, but
Bruce, a MN Galoot
I would think that having false fences, so to speak, would be more work than moving the fence incrementally.
Shims on fences - works great. Makes things easily repeatable. I primarily have used them for my table saw, but I have used them on my router table.
I have a cut out in the middle for the bit.
Merle
Yes, there is an article in the current FWW describing how to do this. The author used 3 (IIRC) shims of graduated thicknesses with an opening cut for the bit. He removed one after completing each set removing the thickest one first.
Jerry Holloway
Thanks everyone..
I will look at the one in FWW before I make mine.....
Hal
I'm inclined to agree with Bruce. When making raised panel doors, I usually make three cuts with the last one leaving no more than 1/32" (I try for less) for the final cleanup cut. For multiple doors, I cut all the panels to size, then run them all thru for the first cut, then the second cut, etc. My router table and fence are made from plans in Bill Hylton's Router Magic - the fence is easy to move and adjust, and seems easier to me than making a set of shims and securing them to the fence. Just an opinion. Good luck. Hal
