Table find (house sale)
Gary Smyth
I’m stuck. After checking more than a couple of references and opinions I still need a bit of help on the pictured table/dressing table/washstand/sewing table. I’m looking for a comparable table for name, style, and date and value if one cares to volunteer one. This weekend find has an slightly more than ¾” thick, 18” wide single board top, is 36” long and 30” high at the table top, not including the drawers or detached scroll work. It is made of varnished pine. It is not fine furniture by any means, but it has hand cut dovetails on all three drawers (at both front and rear). The drawer bottoms undersides have hand planed bevels to fit into the drawer sides. The drawer bottom is tacked at the rear with cut nails. The scroll work back is 3/8” thick held to the back by three screws. The top drawers frame’s back have 1” holes drilled to relieve pressure. There may have been a mirror at one time as evidenced by the horizonal black mark on the back. Except for the drawers and scroll work the table does not disassemble. The drawer runners are scored but not deep and the inside wood has the grayish brown of age. The legs are turned, tapered (not exactly identical) and appear to be mortised to the apron, but there are cut nails (holes filled with putty) located at points that I would not typically expect to see them like on the top directly over the legs. I have seen the tapered and bulb leg shape on Sheraton furniture style, and one instance of Shaker but the Sheraton is much finer and fancier and the (similar style) Shaker leg doesn’t belong to a table (Milligan desk, Pleasant Hill, KY). The brass hardware is not new but probabably not original. The home it came from was all Italian modern except this and the home was in a "good" neighborhood. There is a lot "right" about this but suggestions, opinions welcome.
