Vise Jigs for Tapered, Beveled, Round Stock *LINK*
William Duffield
If you don't have a patternmaker's vise, but need to hold tapered, beveled or round stock, or square stock at a 45° angle, there are some relatively simple and inexpensive alternatives.
I have built auxiliary jaws that drop right into the wooden chops I have attached to the metal (cast iron) face vise found on many woodworking benches. These appliances work for Record, Jorgensen, Colombian and Eclipse vises, to name a few.
For clamping tapered stock, when the taper is horizontal:
You'll need some 3/4" dowel stock and a 3/4" cove bit (core box bit) for your router. Cut a vertical half circle cove in the front chop. Cut a matching cove in the pivoting jaw appliance and glue in a section of dowel.
For clamping tapered stock, when the taper is vertical:
Cut a horizontal cove in the rear chop. Cut a matching cove in the tilting jaw appliance, and glue in a section of dowel.
Note the three notches in the bottom of this jaw. It is best to cut it a little wider than you need, so that when it rests on the vise bars, the dowel doesn't quite engage the cove, and then remove the notches with a rasp, until it rests on the bar with the lower bevel parallel to the rear chop. Thus, you need one less hand to hold it in place while inserting your tapered stock.
For clamping tapered and beveled stock, for example a tapered leg for a bow front table or sideboard:
Use both of the auxiliary jaw appliances you just made. Here''s another photo, showing the two jaws clamping tapered, beveled stock.
When making these jaws, I find it easier to cut the cove before cutting the bevels.
For clamping round stock:
For clamping smaller diameter stock, these blocks are reversible:
They drop right in, and hook on the left side. The hook keeps long, heavy stock sticking out the right side from from pulling them out of the vise jaws. In case you want to hang something out the left side of the vise insead of the right side, you can turn them around, in addition to swapping their order.
When you lay out the V-slots, make sure you leave plenty of wood at the bottom of each V, and don't line them up, back to back. I snapped in two the first pair I made. If you want to get really complicated, you can use these with one of the taper jaws to hold tapered round stock.
For clamping diamond shaped stock, for example shaping or carving a cabriolet leg:
Use the v-blocks that you made for round stock.
These appliances happen to have been made for my Loxiliary Meta-Bench, but they work just as well on any face vise on any cabinetmaker's bench.
I didn't invent these ideas. The jaw with the vertically pivoting axis was adapted from one made by Steve Latta, and his idea probably came originally from the often missing attachment to the Emmert patternmaker's vise, a reproduction of which is sold by Patrick Leach. (See link, but note that the Emmert appliance will not work with a regular woodworking face vise, because it has a center post that goes through a hole in the back jaw of the Emmert and is pinned in place so it won't fall on the floor.)
Of course, V-blocks are standard appliances for machinists. All I did was to adapt the ideas to materials I had on hand and the tools often found in a woodworking shop, and fitted them to the available vise and to the bench I was building at the time. They seemed intuitively obvious when I was building the Loxiliary Bench.
Here is a photo of Steve Latta's bench with the auxiliary jaw in place. He is laying out banding and bell flowers on a bow front Federal table leg. If the angles look a little skewed, they are. The beveled front face is up, and the leg is tapered on the bottom and inside faces. Steve only needs one tilting jaw because he is not going to decorate the side face of the leg. You can see one jaw of the F-clamp he is using to clamp the leg of his auxiliary bench to the top of one of the Hay Cabinet Shop Nicholson benches.
I have also built auxiliary jaws for my patternmakers vise that are also equipped with horizontal and vertical V-shaped grooves for holding leg posts at a 45° angle. These are very useful for carving legs that are symmetrical to the corner of the piece of furniture. I'll leave it as an exercise for the interested apprentice to figure out your own solution for the front legs of a Chippendale claw and ball chair, in which the outside side face of the post is typically at about 82° instead of 90°.
Déja vu? This is a repost from the Hand Tool forum of a repost of a response to an esoteric discussion of mechanisms for keeping jaws parallel on leg vises. It was suggested that it might also be of general interest to those who eschew hand tools and never venture from the dark side, so here it is.
Leach's Tilting Jaw
Re: Vise Jigs for Tapered, Beveled, Round Stock *LINK*
I have a perfect jig for this...
it is called a "shaving mule" :D
Re: Vise Jigs for...
Tom Dunlap
Thanks for the pics. When I setup my shop I'm going to make a set like that for my vises. One will be in wood, the other metal for the welding/metal fab shop!
Tom
Re: I have a perfect jig for this...
William Duffield
Curious! I've seen lots of shave horses, mules, and even zebras (many different designs), but I've never seen anyone put auxiliary jaws in one. ;)
There can be a few minor disadvantages to a shave horse, for my applications anyway. For carving cabriolet legs, the shave horse jaws would tend to dent the show corners of the leg post, and that would remain visible on the piece of furniture for ever. For inlay banding applications, you'd need a separate table at hand to lay out all your other tools and inlay stock while you worked on the leg. Also, for some designs, the inlay is worked from one end of the leg to the other, leaving no room to clamp the end of the leg.
For sure, my vises and jaws are not the most effective tools for fashioning Windsor chairs, or Shaker chairs, or other derivatives of that technology.
William, thanks got sharing that.
Keith Newton
I'll be making some of those, along with a nice place to hide,,,,,,uh store them underneath the bench.
Re: William, thanks got sharing that.
William Duffield
A couple of storage ideas:
When mine is not on my bench (or in the back of my Scion with the work-mutt), it's under my lathe. It's great ballast. I made it almost too heavy, partially due to the old vise that selected me to put it back to work. I have to be careful to keep the vise closed until I get the bench clamped down, else it falls on its chin. The center of gravity is about centered on the left row of dog holes in the left leg. If you need to pick it up, just whack a pair of holdfasts into the top between the vise and the left leg.
If you go look up Bob Lang's 21st Century Workbench, you will find a split top with four short, removable tool trays. I figure you could pop a couple of them out and drop the meta-bench in, giving you an extra end vise on your joiner's bench.
Here are a few pictures of the Loxiliary meta-bench, that I posted on the Hand Tool Forum in response to a query.
I have lots more, and also a few pictures of a few others.
Here's an enticing photo of the undercarriage, demonstrating one method for holding it down on a joiner's bench, and hints of the vise mounting arrangement, and the back side of using a holdfast to hold a piece of wood to the front face.
HTH! I also have photos of more construction details, work holding arrangements, and accessories. If I don't have a photo or a measurement of a detail anyone is interested in, it's easy to go out to the shop, get it, bring it back in and post it.
