OT Patching Asphalt drive way
Anyone have experience patching asphalt?
One of my rental houses has an asphalt drive and the end of it where it meets the gutter is cracked and missing for about two feet. Somebody before me filled in the hole with gravel. My tenant complains that the Air Dam on the front of their car scrapes is the pull straight in and they have to come in at an angle.
I looked up asphalt cold patch on the Internet and found some (US Cold Patch, I think) that gets High marks, that was supposed to be available at HD. Home Depot was oblivious, but they did have some other brand.
The US Cold Patch stuff supposedly attracted moisture from the surroundings and set up firmly with traffic.
So, any experience? Any advice? Should I hire somebody that can bring hot mix? If I do it myself should I dig out some of the gravel and make the patch maybe 4" thick?
Re: OT Patching Asphalt drive way
Lee Schierer McKean, PA
We used some of the bagged cold patch at my son's house. The trick is to lay it in the sun to get the bags hot, have the area prepared and dump the hot material in the hole or space and tamp it down with a hand tamper. Tamp thin layers as you won't compress it if it is more than 1-1/2" deep. Add more until it is slightly higher than the surrounding drive area and then drive your car over it the heavier the better. You might want to put some plastic down so it doesn't stick to the tires. Pack it down as much as you can while it is still warm. It will harden up just like the drive way. Be sure to seal it after it is completely settled and has been driven on for a while.
Lee
Hal
I think Lee's approach will have you on the right track. For compaction, go to a rental center and get a heavy duty tamper. The ones I'm familiar with have a square (about 12") steel plate welded to a steel pipe. They're heavy and will make an old man of you in short order, but do the job. By all means lay your patch in thin lifts for good compaction. Good luck. Hal
Galen Vetterick
This may be a stupid question but if the hole is filled with gravel and the car drags then how is filing the hole with asphalt going to change that? If the angle is the problem than you probably need to tear out more asphalt and change the angle. May be easier to hire it done for the dirt rework and larger amount of asphalt. :\
Thanks and good observation
You are correct about the angle. I had them back the car out slowly and it does drag just barely when the tires drop into the depression where the gravel is. The gravel firmly compacted but about an inch or inch and a half low. I have never patched asphalt before, but instinct tells me I should dig out some of the gravel, trying not to disturb the base underneath and put in a patch in lifts building to a depth of about four inches and about an inch or so higher than the gravel is now. In other words, take out about three inches of gravel and put back four or five.
