topcoat over oil ?
frank ashmore
How long should I wait to cover a watco oil coat on ambrosia maple ?
topcoat over oil ?
frank ashmore
untill it is cured......
Bill Tindall
and that depends strongly on temperature and humidity. It might be a couple of days or a week. If there is a test to know when it is cured on the wood I don't know about it . However, you can put a film on a glass bottle and tell when it firms up and presume the film on the wood isn't slower.
Re: untill it is cured......
Bill Howatt
I don't know how good it is but I use the "sniff test" at least as a clue. If the finish still has a noticeable smell then it isn't cured. I can't define noticeable to any degree but if the smell is obvious then I certainly don't consider it cured.
Bill
