Exterior Clear Finishes
Bruce McCrory
I have made a durable clear outdoor finish my quest for the majority of my adult life. Unless you live in a desert where a finish doesn't matter, most finishes never last more than one winter, and others less than a few weeks. The goal has been a finish that refrains from cracking and shedding and, prevents intrusion of mold/mildew. The quest has included numerous concoctions.
I found another possible recipe. I wonder if anyone has tested it, or uses it?
The reference is from an article on the Hardwood Lumber and More site; ‘Paint on a Clear Exterior Finish’… http://www.hardwoodlumberandmore.com/Articles/ArticleViewPage/tabid/75/ArticleId/26/Paint-On-A-Clear-Finish.aspx
The author, Steve, recounts a post from the Wood Magazine Finishing and Refinishing Forum, by Jim Kull. There is a lot about dogs peeing but the edited version picks a universal subject, oak entry doors and what can protect them best. In this year-long experiment the author focused on the neutral base materials which the colors and tints are added to.
The neutral base ‘paints’ were semi-gloss acrylic, semi-gloss oil-based polyurethane floor paint, a semi-gloss oil-based trim and siding paint. The fourth door was finished in a “consumer” spar varnish.
The oil-based paints survived weather, irrigation, dogs and birds best. Regional climates are another factor in paint durability, but the efforts by Jim Kull typically are much harsher than a normal door is expected to weather.
Before I try, just wondered if anyone has experience with neutral-base paints, sans pigments?
Re: Exterior Clear Finishes
PaulSV
No experience using paint bases without pigment, but I would check to make sure the pigment isn't what gives the finish its UV protection.
Best clear exterior finish I have ever used was spar varnish over epoxy. The epoxy gives a hard, waterproof finish, but it has no UV protection. The varnish provides UV protection, doesn't crack, and is an easily renewable surface. The method is described here:
http://www.westsystem.com/ss/varnish-over-epoxy/
I used this finish in the teak and mahogany on my classic whaler, and it still looks like new, after 5+ years. It sits outside (but mostly covered) 8 months of the year, and is stored indoors but unheated (freezes and thaws) the rest of the year.
The tricks are (1) to use West System 207 catalyst with the 105 resin (other catalysts will give a cloudy finish). You can thin the first coat slightly per the West System directions. (2) Be careful applying the epoxy. It will run if you apply too much, and its about a b**ch to sand out runs I resorted to a very sharp chisel to cut the runs and drips down before sanding. Best if you can apply the finish when the piece is lying flat. I prefer to do one coat of epoxy at a time, and let it fully cure, and then scuff sand before the next coat. (3) Use a high quality spar varnish, like Epifanes. Make sure it is an exterior varnish with good UV protection. Apply it and let it fully cure in a low humidity environment.
You can get all of these materials at any decent marine shop, like West Marine, which has retail stores all over, and a good on-line store. This gives a very deep clear glossy finish. This is great for mahogany on boats, but no reason you couldn't tone down he shine with a semi-gloss varnish. It is very easily renewable, as you can easily scuff-sand the spar varnish and apply another coat or two. As I say, I have had it on my boat for 5 or 6 years, and haven't had to do that yet.
Bruce McCrory
Hah!
Yesterday, I spent most of the day sanding the very same finishes! The Epifanes is a snap, like all varnishes. I just did the knock-down sand, and rubbed the third coat into one cedar chair I am doing.
The second chair has the epoxy, and at two coats is a nightmare to flatten and smooth. Thinning it only works a little better. I am going to do the rest of it in Epifanes, rubbed, to reduce that glass-look.
Both of these materials are godawful expensive, so was looking for something in a palatable price level. I have cedar everywhere, and decks have been relegated to clear finishes. For vertical, rough finish, nothing is better than solid latex.
PaulSV
Well, I guess I was preaching to the choir. :)
You are right, it is very expensive, and it's a lot easier to do on a large flat surface, than something like a chair. I think it might be useful for something like an entry door, where you can take the door into the shop, and apply it horizontally to a large surface. You really can't thin the epoxy much- If I recall, the instructions say you can only thin 10%. I found a cabinet scraper to be usefull in levelling out bumps and runs in the epoxy, once it is fully cured. I do like the Epifanes better than any other spar varnish I have found.
