I would like to use the Soss (invisible) hinge, either the regular or barrel type on some lite doors 16" x 16". Do you think they would work with a touch latch. I used them a long time a go & seem to remember they did not retract perfectly when opening & closing which meant I had to have a larger than desirable gap at the other end.
I would only use Soss hinges on a lid, and would rather use euro hinges for a door, since they have lots of adjustments. However most have a spring closing the last few inches as they close, so the touch latch has to be strong enough to overcome that, unless you can take that spring out.
most of the time, when I use touch latches, I use them on inset doors, but sometimes, like today, I used 4 of them on full overlay doors. Rather than risking having one catch, with little or no margin for not having enough distance for it to disengage, i cut a tapered rabbet in the back of the doors, giving it plenty of room.
If you have never used touch latches, they can be pretty tricky to install. However, I have come up with a technique that makes it pretty easy, with no need for a tape or other measuring tools.
I have used SOSS hinges for years but for future projects I will be switching to Euro hinges. I have used SOSS because they are less obtrussive. But I have too many alignment issues with them and they are very unforgiving for adjusting.
I don't think any of the Soss hinges will work with touch latches. All the ones I have used, flange and barrel, come together at closure. There would not be any over closing to compress the spring in the touch latch.
