Finish for dogwood endgrain?
Brint in Richmond, VA
Is there any way to finish endgrain on dogwood? Everything I've tried so far just turns it the same dark, muddy complexion...
Re: Finish for dogwood endgrain?
I've never finished dogwood endgrain. However, on other problematic endgrain, I usually sand to a higher grit (320 vs 220, etc.).
After sanding I use a half cut of a shellac (e.g. 1 lb) or a lighter coat of polyurethane or whatever I'm using to finish the piece. I then let it dry before putting a full coat.
In my opinion, all of the porous endgrains should have a light seal coat. I remember finishing a goblet that just sucked finish from the bowl down to the bottom of the stem.
YMMV.
more sanding
Bill Tindall
Start with 100 or 120 grit and sand until there are no dull spots. Then proceed to 120, 180 and maybe 220. If at 180 the surface is not uniform shiny go back to 120 an sand some more. A light colored shellac or water based acrylic finish will keep the wood light colored.
Re: more sanding
NickinMass
And make your final round of sanding with an already used (pre-used? pre-owned?) piece of garnet paper in whatever grit you're using. Garnet dulls with use (as opposed to AlOx, which tends to fracture), so used garnet paper can burnish the end grain. This will reduce the amount of finish that the end grain will suck up.
Re: more sanding
Joseph Mulherin, sr
Learned another method for sanding to get a shi8ny gloss on the wood.....
Try cutting a round piece of grocery brown bag and attach it to your ROS . said it will produce a good shine on most any wood.....almost alike using 1000 or 2000 grit.
Thanks, guys. I went with more sanding, up to 400, and that seems to have done the trick. I'm making a small (3") dish for my daughter to put jewelry in, so I can't use my ROS - it's all hand. But initial results for both wipe-on poly and sanding sealer look good on a piece of scrap. I'll post photos when finished.
Thanks again -
Here are the photos, as promised. First, a group shot:
Next, the disk on which I did a side-by-side comparison of Minwax Wipe-On Poly (left) and Zinsser SealCoat (right). As you can see, there is virtually no difference:
Here is the disk I tried Ceramithane on (on the left in the group shot):
And lastly, Waterlox (on the right in the group shot):
I like the tone and the clarity of this finish the best, so this is the one I'll go with.
