Raised shop floor
Tom Dunlap
There is a barn at the place that I'm renting that will become my workshop. The floor is poured concrete but shovels were used to smooth the surface not floats...really bumpy. Worse than that the 16x24 main part has one half that's about 3" taller than the other. Then, the other 16x24 part steps down another 3" or so.
My landlord has a lot of 39x41" x 7/8" plywood squares. i don't know how many plys. Nice solid stuff! It would make a really nice floor.
I have access to as many hemlock sawlogs as I want. they have no commercial value so the wood is free, all I pay for is the milling.
Here's my plan...
Have the hemlock milled into 2x4s. Lay these on the flats to become, I think they're called sleepers???. Each plywood edge would have half the 2x4 to rest on. the edge of the whole works would be 2x4 on flats too. Shims and blocking would be added to level the whole works. The plywood would be screwed down.
I've considered raising the floor enough to install ducting for dust collecting underneath. there would still be enough headroom. Having it underneath would be soooo nice.
It seems like the best way to layout the 'sleepers' would to follow this sort of plan:
http://www.homedepot.com/webapp/catalog/servlet/ContentView?pn=KH_FL_Laying_Tiles
I used the Sagulator to get some sort of idea of how much load/flex to expect. It seems like the 7/8" ply shouldn't need support in the middle.
Since I have so much wood I'm also thinking of having 1x6-8 boards made...maybe 5/8 or 3/4...and nailing them up to panel the inside. Let them shrink in place and not worry about the cracks. I might put off the paneling if I can calculate the drying rate over the winter here in Asheville. There is plenty of room to sticker and air dry. It might be worth stalling out the paneling if the shrinkage is too much.
Are there any suggestions or considerations that I'm missing? This is rental property so I don't want to put a lot of time or money into it in case I move out. My landlord said that he might cover costs...wait and see how much the milling costs.
Thanks,
Tom
. I would also have 2 layers of plywood - even though you think it won't sag.
