OT: Bearing Replacement Help
Stuart Johnson
We have an elliptical machine that gets a hard two hour a day work out. Some of the bearings have finally started to grind and growl. My problem is I don't have any idea how to pull out the old ones and install new ones.
This photo shows one end of the pedal arm. It has two bearings with a spacer between them. The other end is similar with different self aligning bearings. I suppose I can just beat out the old ones but that doesn't seem the right way plus I still need to figure out how to install the new one.
What is the proper way to handle this?
Re: OT: Bearing Replacement Help
Bill Tindall
The surest way to success is to take it to a machine shop. There is ample opportunity to wreck something replacing bearings if not experienced.
Bill Turpin in WNC mountains
You can probably press one bearing out thru the middle and take out the other. A machine shop should be able to do this for a few $ and press the new ones in. If you attempt for self, press only on the outside race.
Dick Coers
As thin as that tube wall is, I doubt if it has a hard press on it. You can use sockets and all thread rod to replace them. Use a socket sized to fit inside the tube, (but still on the outer race) and another that will register on the tube, but let the outer race of the bearing slide into it. Run a piece of all thread throw it all, and use wrenches to pull the bearings out. Reverse the operation to install new bearings.
That's what I'm thinking too...
John in NM
Looks like it would be pretty easy to do as you describe, or with sockets and a big C-clamp - I used to do U-joints that way.
If we knew we were replacing bearings, we always knocked them out from the far side with a drift (long pin punch), applied against the inner race. It ruins the bearing, but if you're replacing it because it's gone bad, it's already ruined. Good suggestions on installation, although I will confess that, for a simple bearing insertion like that, I've done it by very careful tapping with a piece of brass or hardwood against the outer race ONLY, going round and round and round so as to keep it going in straight.
Far too much automotive repair with inadequate tools in my lifetime...
Bob
Bob
I would take it to a machine shop they can do it in minutes and may have the bearings in stock ask for self alining bearings as well. You may loose hours doing it yourself, I would look at that weld it don;t look to good, have them beef it up.
Stuart Johnson
Thanks everyone. I have all the bearings so I'll give the socket and all thread a try. The actual bearings are pretty inexpensive so at worst I'll mess them up when I try to install the new ones.
General principles of bearing replacement
Ball/roller bearings almost always have a tight fit in either inner or outer diameter, and a ever so slightly looser fit in the other dimension, to permit assembly*. Which fit is tighter will usually become obvious during disassembly, although at times you just have to think through the logic. Installation requires putting the bearing in/on the tighter fit location first, with the pressure/driving force being applied to the race (inner or outer) that's touching the shaft/housing. Final assembly then requires gentle force to seat the other component in/on the bearing's other race, so you don't stress the bearing.
This case is obviously one in which the tight fit is to the housing for the bearing.
*The exception here is tapered roller bearings of the type in which the outer race can be separated from the inner race and roller cage. These are often equally tight-fitting both in and out, because they're put in place on the components before assembly. Many older automotive rear axle outer bearings are of this type, for instance.
