Refiniishing a shuffleboard table
Joe Caras
I would like input on the best sealers or finishes to use to finish a shuffleboard table.I had a guy tell me to use tung oil and wax it.I want to make sure Iam getting the best possible finish and playing surface.Any shuffleboard refinishers out there? Thanks Joe.
Re: Refiniishing a shuffleboard table
William Duffield
To start with, some questions need answers: What was the previous finish? Why does it need to be refinished? Are you planning to totally remove the old finish (without damaging the triangles, trapezoids, and point scores)? Do you really expect to find any professional shuffleboard restoration experts here ;) ? Some of us geezers are old enough to know how to play shuffleboard, but mostly you'll find Foosball and Super Mario Brothers aficionados.
Without answers to these, I would suggest the following general guidelines:
First clean off all the existing wax. Mineral spirits or naphtha should work. Seal the old finish, so the new finish will stick. A dewaxed shellac will stick to just about anything, including Teflon®. The easiest to find and use is Zinsser SealCoat. For this application, you need a finish that is HARD, because any subsequent dents will give someone who knows where the dents are a significant advantage. Therefore, I would recommend a nitrocellulose lacquer. (Spar Varnish and other mostly oil finishes, which are tough but flexible, gravitate towards the other end of the spectrum.)
Richard McComas
Google is your friend on this one.
This is one of many I found.
http://www.zieglerworld.com/shuffleboard-refinishing-tips.htm
