Drill Speed?
Drill Speed?
Drill Speed?
What's the max safe speed to run an auger bit? My press only goes down to 250 and I've got 5/8" holes to bore 5 1/2" deep, end-grain, in table legs. Don't have a twist drill that big that long.
tia
m
Re: Drill Speed?
Re: Drill Speed? *LINK*
If you're talking a true auger bit, like the kind that go in braces, no way would I run one of those in a drill press without filing the screw center into a brad center. The thought's just too scary.
There are tables, one linked below, that may help. I'd consider the thought that ship augers (the closest power equivalent to an auger bit that comes to mind) are generally used in 1/2" drills that have a max RPM of, say, 750, and maybe use that as a benchmark.
Unless this will be a highly visible hole, where scorching of the wood will be an issue, I'd err on the slow side. An extra few minutes of drilling is nothing compared to watching your carefully selected table leg stock get ruined...or your day, as the auger bit twists into a pretzel bit, throws the leg into your stomach (or worse), and terrifies the shop cat.
http://www.wwch.org/techdata/DrillBitSpds.htm
Re: Drill Speed?
like this auger?
John in NM
I've run these, 5/8" and 7/8" on my lowest speed, probably around 500 rpm (drill press is old enough not to be labeled). Ground the screw point to a brad point first though, otherwise the best it will do is split the wood, worst something along the lines of what Bill mentioned.
Re: Drill Speed?
Re: Drill Speed?
Hal
Check out Colt bits. They make brad point bits in various lengths. I have a 1/4 x 12 rated at 1750rpm min. & 3750 max. Larger dia. would likely be slower. They are excellent bits - like the guy said in the commercial we saw over and over a couple years ago; you know the Germans, they make good stuff. Woodcraft among probably many others sells them.
Re: Drill Speed?
Got'er Dun
Although not easy, I managed to run a search on the Irwin bit and it turns out they approve anything less than 1000 rpm. Knowing that screw point would be aggressive, I locked everything to the press table and went in at 250. As anticipated, the screw point wanted to pull the auger down and the work piece up, but my press jig table was up to the task and things went smoothly even with the 6" bores done in two stages since the press' maximum travel is 4".
Yes, wore eye/face protection and a shop apron (not Kevlar however).
Yes, used extra light on the operation.
Yes, the DC was hooked up and running.
No. Did NOT have my beer within reach of either myself or the workpiece.
Thanks guys. :)
m
Re: Drill Speed?
"Did NOT have beer..."
"Did NOT have my beer within reach of either myself or the workpiece."
Is this a major problem in your shop? Man, I knew you guys back in Joisey had it rough, but I didn't know you had to contend with your wood getting plotzed.
Re: Drill Speed?
No Problem
It's a new alcohol drying process in the research phase.
Re: Drill Speed?
Re: "Did NOT have beer..."
George Colonel's Workshop
Good Afternoon Bill,
I always have a beer nearby when performing similar procedures at the drill press. The beer is used to lubricate, calm, and cool the bit and the stock.
George
Re: Drill Speed?
Lubrication and Coolification
I'll drink to that!!
Re: Drill Speed?
PS
Reference is to drill press definition:
"A tall upright machine useful for suddenly snatching a workpiece out of your hand so that it smacks you in the chest, exposes the outer tendons of your left thumb for easy daylight inspection, and then flings your beer across the room."
Re: Drill Speed?
Re: Lubrication and Coolification
Joseph Mulherin, sr
SKOAL!!!
Re: Drill Speed?
Starkle, Starkle
Lil Twink.
Who the hell I are, you think?
I'm nev-v-v-ver unner tha afluence of incahol,
Tho some thinkle peep I yam.
[Note to editors: There is no place for mind-altering substances of any kind in a wood shop, be they absorbed, swallowed, or inhaled, and nothing in this thread should be interpreted to the contrary.]
Re: Drill Speed?
Actually
It was and remains my most favorite bar napkin of all time. :D
[Author unknown.]
