THE WOODRAT IS BACK!
Washing machine recommendations please
Bill Tindall
I live on a farm in TN. Clothes get muddy, greasy, soiled with sheep poop. We have no water shortage here and electricity is ample and cheap thanks to TVA. Hence, the washers targeted, if not mandated, to apartments in CA are not optimum for our needs.
Is there a washer still made that uses ample water and electricity to get clothes clean in a minimum of time with out controls rivaling an airplane cockpit? A circa 1970 washer would be just grand.
Re: Washing machine recommendations please
Ken Oakley-Sunny St. Cloud, Fla
Anything but LG. Their appliances are pure junk.
Bosch
doug f, san clemente, ca
Bill - based on some referrals from several folks I know, we bought a heavy duty Bosch about 4 years ago. We pile enormous amounts of junk into it and it inevitably comes out clean and fresh.
My only con regarding the machine is that the wash cycle is a bit long, but otherwise a great machine.
Doug
Re: Bosch
Gerry in North Surrey
We bought one of those @#$%^&* front loaders a few years ago and I ain't happy with it. On a recent trip into Oregon I washed a load of greasy overalls worn while firing a coal burner in a Maytag Commercial agitator top load in a Motel 6. Set the water temp (hot), set the cycle (heavy soiled), chucked in a 1 buck box of Tide powder from the machine on the wall and 45 min later I had brand new coveralls. Worked like a damn. When my schedule settles down a bit I'm going shopping for a used/rebuilt Maytag Commercial top loader and that damn front loader is going over the fence into the ravine.
Gerry, who now has to go to a Motel 6 to get clean clothes.
Re: Washing machine recommendations please *LINK*
Dave's Not Here
I recently purchased a Speed Queen AWN412 and couldn't be more impressed. This machine is built like a tank, stainless steel wash drum, metal(not plastic) gears and very basic controls. AFAIK, the Speed Queen line is also the last of the Made in USA(Ripon, WI) washing machines. They're not the cheapest machines around but there's a reason you see them in most laundromats.
Speed Queen AWN412
now we are talking
Bill Tindall
Going to go look at this one. Any description of a washer that begins "commercial quality" rather than "saves" 10 cents worth of "water" per load gets my attention. I pump 100 gallons of water a minute out of the river to irrigate. "Saving" a gallon doing the wash is foreign to my thinking.
read the reviews......
Bill Tindall
The EPA water limitation requirement is readily defeated on this machine, a warm water rinse is easily arrange. The warranty is astonishing. I suspect we will be buying one Tue. 30 min wash cycle. Thanks for the recommendation. It seems to be the machine of our dreams (that is 1970 dreams).
Saving? Water?????
I am slightly baffled by the concept of "saving water". If my guess is correct you are on a septic system. So how is that not running water through your washing machine saves it? Or turning the water off and on while brushing your teeth saves it. It seems to me you are recycling the water by cleaning your clothes (Or teeth) with it, dumping it into a system that allows it to soak into the soil and evaporate and then return to the system as nice clean rain. the same is true of people on municipal systems. They don't destroy the water or remove it from the Earth, they clean it and return it to the world. I suppose you could argue they might save a little money by not have to clean a few extra gallons, but OTOH the water they get would be dirtier, not being diluted by the clean water you "wasted". OK, I'm finished ranting now.
Can't help you with the washer except to tell you I have had three front loaders and combined they have no lasted as long as the top loader they replaced. Wonder what the environmental cost of replacing washing machines is? Oops, apparently I was not quite finished with the ranting.
Jim in Burlington Ont.
Maytag Commercial
Jim in Burlington ON
Hi Bill,
You can buy Maytag Commercial washers fairly reasonably priced. Just call up a dealer and ask them for a price. If your looking for a real workhorse that will wash larger stuff as well such as duck bill winter coats you can keep your eye out for one of the laundrymat industrial front loaders.
Speed Queen delivered
Bill Tindall
1 st load through it already. By teeing the hot and cold we can get a warm rinse, important when our winter water temp. is 40 degrees.
Love it
Bill Tindall
This is the machine for those that don't like the government telling you how to wash your clothes. Need more water than EPA thinks you need? No problem, just tell it to add more. Short wash cycle. Manual setting for all important variables. Called at 10 AM to order it and we were washing clothes at 11:30.
