ot oil water emulsion
Jerry Gibbs
I have a diesel engine in my boat that holds 12.6 gal of lube oil. Extraction of all oil is difficult. I am lucky to get 10 gal. I have water in the oil. That problem has been fixed, but I need to get all the water or oil/water out. One method is to remove as much oil as possible, add new and keep changing until there is no trace of water. This can get expensive. My question is whether the oil/water emulsion that I have removed and saved will separate so that I can re-use the oil, at least in the cleansing process. The mixture became an emulsion (if my chemistry is correct) because I ran the engine to heat and thin the oil for removal. Wanna buy a boat? Jerry
Re: ot oil water emulsion
How about centrifuging the mixture? Another thought is a very large separatory funnel. The commercial oil/water separators are way expensive.
A separatory funnel (2 L or 2000ml) runs about $75. You might find a used one for less.
Thoughts about the Problem
Bill Tindall
1. Problem 1 In principal the easiest way to get the water out is to add something that will dissolve both oil and water and then pump it out. However, that leaves 3 gallons of this ingredient in the tank and it will screw up the new oil to be added. You really need to devote thought on how to pump/drain a greater fraction of the stuff in the tank out of the tank. There seems to be no substitute for doing what is needed to drain the tank dry.
2. Problem 2 Lubrication oil is a complex mixture of Oil and a host of other ingredients that affect corrosion, viscosity, stability etc. There is no guarantee that oil exposed to water still has all these essential ingredients still in the oil and not extracted into the water. Personally I would not attempt to reuse oil separated from water.
Amen, it isn't worth the risk
Sounds like you need a longer hose on your pump; 3 gal. is a lot to miss on a pump-out. Decent boat yard should be able to get that pan dry.
The emulsion is toast without special equipment which you ain't got.
missing oil
Jerry Gibbs
other owners have same problem, but thanks for the comments. Jerry
Kneale Brownson
Re: missing oil
Kneale Brownson
A lot of gear oil housings are difficult to empty. But most have a cover or pan of some sort that CAN be removed to get it all out. Whoever fixed the leak should also have removed the oil.
