Card Table
Card Table
Card Table
Lee Schierer McKean, PA
A number of years ago at one of the 5 Barns picnics, someone had several inlaid table tops that had been damaged by water, that they were giving away. I liked how they looked and thought I could cure the water staining. It stayed in my shop for far too many years. LOML had a card table we often used on our deck as a side table when we had 6-8 people dining with us. Last year the old table was left out on the deck during several days of rain and the top de-laminated.
I decided to clean up the inlaid top and see what I could do with it. After several cleaning steps, I managed to get nearly all of the water staining out, so I decided to build it into a table. I made a black walnut frame to support the top and located some 8/4 walnut for the legs. With the help of folding table legs from Rockler I was able to produce the table you see in the photos. The large squares look light and dark, but if you rotate the table 90 degrees, the color shifts on those squares. The legs taper from 1-1/4 at the top down to 1" at the bottom. The finish is 5 coats of Deft Clear Wood Finish in semi-gloss.
Thanks for viewing,
Lee
Re: Card Table
Jim in Burlington Ont.
Re: Card Table
Jim in River Oaks, Ont.
Great work Lee,
I have used that same water process to delaminate lots of work I am glad to see I am not alone there, LOL... great recovery!
Always great to see your work my friend,
Take care,
Jim
Re: Card Table
Re: Card Table
Stephen Kirk
That's nice, always good to see things getting reused and turning out very good looking.
Re: Card Table
Creative solution, Lee
Plus, you get the reward of having one less miscellaneous item lying around the shop. I wish I could use up some of the things we've been hoarding.
Nice work. Thanks for posting it.
Re: Card Table
Just to be clear
It was the old table that de-laminated, so I needed to make a new one with the table top that had kicked around in my shop for years.
Lee
