poly finish help
vamatt
After spending countless hours meticulously sanding and then a mineral spirits cleaning, I brushed on full strength poly unto walnut slab countertop. After letting it dry for ten minutes or so, I noticed splotching from some contamination (silicone maybe). I quickly wiped off the poly with cloth and then again with cloth and mineral spirits. I'm going to seal the top with shellac based sealer then use the poly. My question do I need to strip with chemicals before applying the sealer? The piece has been drying for 12 hrs, is dry, and the blotching is gone, but it looks like I put a coat of wipe on poly on it. So there might be residual poly in the pores. Any help is appreciated. Also does sealer affect the durability of a finish?
