A few recent shop test.
Keith Newton
I have a young fellow helping me now. He likes the learning process, so I try to explain, or even back up certain things with experiments.
A while back, we were using some epoxy, and I stated that I really like the one that I use now, in that it is a 1 to 1 mix ratio, and is very forgiving, if you don;t get it perfect. One thing I didn't like back when I used the pumps, was that as they aged, or too cool, air would get drawn into the pump chamber, which could throw off the ratio, for a very unforgiving formula.
Back when I first started using this brand, I remembered the sales rep telling me that this formula was so forgiving that it could be off as much as 1 to 2, or 2 to 1, and still would kick. But one of those ratios would make a more flexible plastic.
I had never tried that, so we mixed up two batches to those ratios, and mixed half of each thick as peanut-butter. Ben guessed that the 2 resin, 1 activator would be the flexible one, but I told him, I thought it would be the other, and I was right. That is why I'm the boss. ha ha.
Then last night, we were discussing the hp listed on the shop vacuums. I told him about a little experiment I did a few years ago, where I sandwiched my bath scales between two 12" x 12" pieces of mdf, with a window cut out so I could see the weight when I put them in a clear drum-liner bag. With no leal, just holding the bag tight around the hose, a little 1 gallon, 1 hp, and a 6.5 hp 16 gallon, both Sears, drew ~ 200 pounds.
I had a piece of 1/2" clear vinyl hose, so we tested it another way, including another 5 hp 16 gallon Sears, and a small 5 hp Rigid. The Rigid, an 6.5 tied for the most, pulling 47" of water up the tube, with a wet rag for a seal. The other two were 45". This works out to ~ 235# to 250# pst. which was better than I expected.
). I understand why you would use those units, because if you think about a person who weighs a hundred pounds or two or three with a footprint somewhat less than a foot square, standing on a veneering form you have constructed or on a hollow core door, the results can be pretty intuitive, without a lot of calculations and the chance of misplacing a decimal point.
