OT: Your Thoughts About Airless Sprayer
Ken Krawford
The projects I am building recently have all ended up being painted. I have a turbine based HVLP sprayer but I'm not crazy about how well it sprays paint. I'm considering a Graco Magnum X7 airless sprayer. I've found one for $200 that is fairly new, has been well cared for and in great condition.
Before I pull the trigger, I'd love to hear any feedback (good or bad) concerning my choice.
Thanks in advance.
Ken
Re: OT: Your Thoughts About Airless Sprayer
Dick Coers
I only used one airless when I painted my house. I rented it and man could it throw on the paint! Cleanup was a real hassle with all that hose. If you get it, don't use any more hose than necessary.
Re: Why Airless?
You may want to look into a used Binks or similar conventional gun. IMHO the only advantages of Airless sprayers and or HVLP units is the amount of over-spray and due to less over-spray the amount of material and solvent used is less. In my opinion I can do a better job of controlling the spray with my conventional gun than with my (admittedly inexpensive) HVLP conversion guns. I had quite a bit of experience in using Airless systems at my job before retirement. I never wanted one for home use. In most cases the differences in the amount of material used is insignificant to the hobby woodworker and the cleanup of an airless unit probably releases far more solvent into the atmosphere than the conventional units including cleanup.
I've used a Graco airless to apply pigmented coatings. Does a great job on stuff like louvered shutters and wicker furniture, although its very easy to get too much on resulting in runs and sags. For interior stuff I'd still prefer my HVLP pressure-pot rig, even though I'd be fussing with viscosity.
Bob
Bob
They are good if your using latex paint but if you are doing any spray painting that requires a 1.0 tip your out of luck IMO they are very limited, don't do that good of a job and wastes to much paint. If you can afford it the Apollo 1050 give you a lot more versatility.
Rick L
Re: OT: Problem solving
Rick L
Consider using Penetrol or Floetrol to the paint. I use them even if brushing the paint. There's no reason you can't get a nice finish from a turbine HVLP. Learn to maximize your tools before buying a diferent tool.
