Gluing Teak
Gluing Teak
Gluing Teak
Woodie49
I have been asked to reglue a Teak Door on a Sail Boat. What is the best Glue to use?
Thanks
Re: Gluing Teak
Re: Gluing Teak
Joseph Mulherin, sr
Woodie, I did a search on gluing teak and the best system I came up with was to use the epoxy
G-2 System 3. Clean the joint with lacquer thinner and get all of the oil off the surfaces
before attempting the gluing of the joi9nt. Also, they mentioned using Titebond 2 glue using the same
techniques. They also mentioned Gorilla glue, but I have not had good results with it, and the out-sourcing and sanding did not make the product look satisfactory.
Re: Gluing Teak
Jesper, Denmark
Re: Gluing Teak
Jesper, Denmark
You need to get all the old glue off and get down to clean wood. Prep the joint by wiping with acetone to remove surface greeasiness.
Weldwood is good, and it's brown color is a good match for the teak if you have visible gluelines.
West epoxy with high and low density fillers to get e peanut butter consistency.
For interior teakwork, any water resistant regular woodglue is perfectly OK.
Re: Gluing Teak
Re: Gluing Teak
Richard Jones
I always use/used Resorcinol. Sort of old school, but works.
R
