Truck bed wood sealer?
Philip Duffy
Buddy of mine is putting white oak on his re-build truck project. Expects light use but exposure to the VA weather. Any ideas on best varnish/oil finish for him to use? Thanks y'all. Philip
Re: Truck bed wood sealer?
How about a deck sealer? Such as Cabot's Australian Timber Oil. You wouldn't need more than a quart.
Another thought is one of the marine varnishes.
Bill Tindall
there are some products for marine use that have some lasting power. But the one I used is very dark amber. check with Jamestown Distributors
paul in AZ
I have no knowledge of truck beds but considerable experience with wood in sailboats.
Your trade off here is function as in hauling things once in a while vs. a bright shiny show piece meant to be admired but rarely if ever used.
Marine varnish was mentioned.
Marine [spar] varnish has as one of it's main attributes resistance to UV deterioration. It is however a relatively soft finish and is very easy to scratch or otherwise break. That is one reason decks -typically teak- are unfinished while "bright work" not exposed to being beat up is varnished.
I would be inclined to look at either a penetrating, non-surface forming oil finish or possibly something really tough like a clear epoxy. Possibly one of the flooring varnishes??
Or just let the unfinished white oak weather to grey.
Dick Coers
At best, wood truck floors are temporary items. It will last for years, but may not always look the best. I would also suggest stainless steel fasteners. Wet white oak can chemically react with steel, and it may stain the white oak black around the bolts. Make sure he does the treatment before mounting the wood so the end grain gets coated.
Re: Truck bed wood sealer? When I was a kid
Carol
it was used motor oil. Function first was the order of that day.
Bob
Bob
Same as we use on the bay. SPAR
Jason Roehl in Lafayette, IN
Whatever he uses, I would suggest something that is easy to re-do, which would basically exclude all film-forming surface finishes.
The bottom line is that he probably wants a clear to semi-transparent finish, which puts him basically at the bottom of the longevity scale. I've not spent more than a few days in VA, but I'll bet he doesn't get more than 1-2 years out of any finish, so he may as well make it something he can just wash, do a quick surface sanding and re-apply. For that, I'd suggest deck finishes from a paint store.
Jason
Howard Acheson
>>>> like a clear epoxy.
You wouldn't want to use epoxy. Epoxy rapidly deteriorates when exposed long term to the UV in sunlight.
Ray - Middletown, in
I would soak them in BLO for several days then let air dry for a month, then put them in the truck. Pour in a gallon every year and swab it around til it's gone. May not be the best looking but I'd bet it would last decently.
Ray
I tried just about everything on some wooden bumpers and canoe racks on my old truck. Everything has to be renewed after just 2 years. It starts to crack the finish and then peels. Spar Varnish lasted the longest but really not tremendously longer than epoxy. I didn't try epoxy that has UV inhibitor in it. Didn't know it existed back then.
I know you don't want to hear this but paint worked the best.
I would probably go with an oil of some sort for the bed of a truck. It would be easily renewed as often as possible. Won't crack when you place something in the truck that would ding a hard finish.
That's just my 2 cents worth.
Philip Duffy
What a great set of responses!~ Thanks to all, and I will pass them on to my buddy. Let him make the choice, not me! Phil
PaulSV
I did a lot of research in choosing a finish for the mahogany on my antique Boston Whaler, which, like a truck bed, has to stand up to weather and sun in all temperatures. Here is what I used:
Three coats of West System #105 resin, with #207 clear finish hardener, thinned about 10%, followed by
three coats of Epifanes Clear spar varnish.
The spar varnish adheres well to the epoxy, and provides UV protection for the epoxy, while the epoxy seals the wood extremely well. After 5 years of use, standing outside all summer, and stored unheated in the Michigan winters, it still looks like new. Eventually, if the varnish starts to wear, I will lightly sand it and apply a few more coats of the Epifanes varnish. It has a very deep, clear shine, like the boatbuilders get with 12 or more coats of varnish.
PaulSV
An additional note: The Epifanes varnish is expensive, but it seems to be much harder and more impervious to water than any other spar varnish I have tried.
Philip Duffy
Tim and Paul, Thanks for those great replies! Phil
