3 yr old water based poly finish
Bob Boswood
I built a cherry kitchen 3 yrs ago. Turned out great. Now the finish on some of the base cabinets only is failing. All the 42 inch wall cabinets are fine. Not sure where I screwed up but it is evident I did not get enough sprayed on water base clear on some of these. I realize I am going to have to sand most of them and start over. My question is on the few where the color and finish are still good can I scuff these up and spray more coats over the 3 yr old finish. I don't want to change the color so I need to stick with
water based poly or something fairly clear. I just do not want to do this again ever. It was my first time using water based poly. Think I will stick with oil from now on. Any help would be appreciated.
Re: 3 yr old water based poly finish
Test
on firewood. ;)
If it hasn't frozen, it should be okay. Be sure to run it through a fine mesh strainer to remove any snots.
How many coats did you apply and how?
I use General Finishes Pro line and apply 3 coats by HVLP.
John Veerkamp
Where the finish is still intact, scuffing and re-applying will be fine. Just be sure to clean well to remove all traces of kitchen oils and waxes.
A problem with water based finishes
Bill Tindall
The technology to made these finishes is relatively new and there is a lot of formulation and reformulation going on to develop finishes that look as good as traditional finishes and not cost a bundle. It is quite likely that any product you are using has only been on the market a few years at most and hence it has not yet stood the "test of time". I got talked into finishing some porch furniture with a Target Urethane that was supposed to be good for marine application. It molded and otherwise disintegrated after one summer on the covered porch. Obviously the accelerated testing done at Target didn't reveal these deficiencies.
People are often using the water based finishes because they think they are free of solvents. In fact they must contain a coalescing solvent to make the film. It just happens that these solvents smell different from the mineral spirits or toluene used in solvent based finish.
The conversion varnishes are performing well for kitchen cabinets. We have 20 year old cabinets with Sherwin Williams Kemvar and it has done well.
Bob Boswood
I usually shoot for 4 coats. Somehow I had to have missed a coat or 2. It was quite a large project for me and my small shop. Happy to find out I can still build the finish. I sprayed with a HVLP gun as well. I sprayed Sherwin Williams as well but I really don't think it was the product nor the delivery method. Just a bone head mistake on my part. Thanks to all.
