Need help with making hollowing tool
phillip medghalchi
I am trying to make some hollowing tools with carbide cutters and wondering that how i can make the shaft bent as like goose neck and at what radius or angle. Also, would be better to have round bar or square. Any help is apprecaited.
Re: Need help with making hollowing tool
Post over on the Turning board.
I've made tools - but they have been straight shaft HSS tools out of steel stock. I've used round steel and square stock.
Grant Wilkinson
I've made two that work fine. Both of mine are made from round stock, but only because that's what I had at hand. I've seen and used one made from square. The key seems to be to make sure that the cutter is in line with the straight part of the shaft. If not, you'll not be able to counter the twisting action on the tool imposed the wall the vessel you are turning.
Dick Coers
If you are talking full size tools, you will need an oxy/acetylene torch to get the 3/4 bar stock up to temp to bend. I used the column of my drill press, along with a bracket on the table, to get the tight bends. Even red hot, it's not easy, so cold bending is definitely out. If you are talking tools like the EWT that has a small bent tip, I imagine a MAPP torch will work fine.
Post this on the turning board and I'll answer
Short answer is you can bend 1/2" rod fairly easily. larger rod will either require some very heavy duty tools, or heat, or both. I've made several and even made a special tool to help. Ask on the other board and I'll try to dig up some photos I have.
Keith Newton
By square, I hope that includes rectangles. I have made some that I like, and plenty of not so good back a long time ago. As for round, it is easy, but the ones I made from just round mild steel tended to resonate, which can amplify and lead to problems like chatter.
The better ones, were made from stainless rectangle stock, which I picked up at the salvage yard. It is a lot stiffer than mild steel, and once the corners are rounded, it has a friendly edge, if it touches the small opening. Also, I might mention that stiffness comes with height of the bar, and as you already know, a small opening, is usually entered from an angle, so the round is an apparent ellipse getting thinner, as you move to the side.
There isn't one "do all shape". Short bends get the inside just in from the opening, and a larger bend gets you a bit more until you start getting back to the straight, calling for an even larger, if you want to continue going wider before going deeper.
While I have some which I brazed on carbide that I like, I think I would recommend that you drill into the end, then use a inserted tip, whether carbide, or other tool steel. If it is brazed on, it is a lot harder to sharpen on fine diamonds, than just holding a smaller tip. Besides, I like changing the shape of a tip for certain types of cuts.
One little tip I will share. If you are needing a square hole, is to drill a round one, then get a square solid carbide. grind a long taper on it, then drive it into the drilled hole while that steel is red hot. Carbide stays the same hardness when it is red-hot as it is cold. You can pean around it, to improve the stresses. Of course, you need to keep the heat on it, and drive it on through. I don't think I ever tried to pull it back out.
As stated, I think a cold bend is out. But if you have a good torch and anvil, you can have as much fun pounding metal as you can cutting wood.
