dust collector vacuum hose
les winter
I want to use my dust collector to vacuum my shop floor. I'm looking to get a 25' length of 4" hose. Does anyone have a recommendation for a good hose?
thanks.
les winter
thanks.
Re: dust collector vacuum hose
You might look into Rockler's "Dust Right" expandable hose. It at least will "collapse" when you aren't using it. It is quite pricy.
Other than that, I would get a couple of lengths of 4" hose that are 10' long. I would go for something with a metal reinforcement as opposed to plastic - but I don't like static. The plastic "wire" also would work fine.
I would go for clear as opposed to black.
Highlandwoodworking, Rockler and Woodcraft are among the many sources.
I Dodat
Works fine except for one thing:
Since I use 2-1/4 shop-vac tools, I had to fit the 4" hose with a reducer. Since I bought lighter-weight [way cheaper] hose, the reduction and restriction in the air-flow makes the hose want to retreat by collapsing the corrugation folds so that 25' hose wants to shrink to about 8'. Heavier hose won't do that, but it'll cost you 3-4 times as much. The other solution is to buy a set of 4" vac fittings.
BTW, trying to vacuum up large quantities of lathe shavings will clog your pipes and/or the DC impeller. The DC is no substitute for the shovel, but it does well for dust and general cleaning.
HTH
M
dan jechura
T & S Tool supply sells 10 foot 4" hose, clear for $10 cheeper than Woodcrafters. I found that out after I bought what I needed.
Iuse my dust collection to vac up a pile of wood chips from my lathe. I have a 55 gal garbage pail in front of my dust collecter and it filled up in a mim or so. I'm back to a dust pan and broom.
Dan J.
mdclor
Les, 25' of 4" flex tubing will create a lot of friction for your DC to overcome. There may not be much suction available at the end of the run. Is there any way you could try it or simulate it before you buy the new tubing? FWIW
