Heavyweight pendulum
Lee Schierer McKean, PA
As others have stated, on a quartz movement, the pendulum has nothing to do with time keeping, it is purely decoration.
It is likely that your pendulum is too heavy for the movement to power for proper swing. You can try starting the pendulum by hand, but it will likely slow down after a period of time to what you see now if it is too heavy. If it is too heavy, changing the length will have little effect on it swinging. The impulse applied by the movement is quite small and excess weight would cause it to be too weak to swing the pendulum.
This assumes your movement is hanging plumb.
Lee
