New Wood
Johnny Narron
I recently cut a pine tree, I am cutting it in discs to do pyrography/ wood burning. I've noticed it is splitting in the center, what is the best thing to do to stop the splitting?
New Wood
Johnny Narron
Not much
By the nature of wood shrinkage, splitting is inevitable in most woods. If you saw a single saw kerf from the perimeter to the pith, that kerf will widen as the rest of the wood shrinks around the circumference of the disk, but you will not likely keep the entire disk intact. Polyethylene glycol is sometimes used to soak and impregnate log sections to keep them from splitting, but it isn't a simple or trivial task, and the resultant wood will have that slick chemical in it forever. Maybe that isn't a deal breaker with your pyrography, but I don't think you can put a finish over it.
Best defense is to use boards that are cut parallel to the grain instead of across it.
Ellis Walentine, Host
Might try...
Dale Lenz
Cutting the cross-cut disk at an angle. Seen many disk in craft stores to use as a clock face. I'd start at say 20-25 degrees and increase by 5 degrees either way to see what works the best. Good luck and let us know how it turns out.
Pine is not good wood for wood burning
Ray - Middletown, in
anyway. But if you really want to use it might try drilling out the center and putting a plug back in after some drying takes place. I like the idea of cutting on an angle also.
Ray
Re: Pine is not good wood for wood burning
Bob Bosworth
Option 1. Saw a disk in half, right thru the pith. Let the halves dry. Straighten the cut faces and glue the halves back together.
Option 2. Place a fresh cut disk in a black plastic garbage bag and tie bag shut. Place bag on pavement in full sun. Next day, untie, remove disk, turn bag inside out, reinsert disk, tie shut and place in sun again. Repeat until there is no longer moisture on the inside of the bag when opened. The bag allows the moisture to equivelate without putting stress on differential shrinkage. I've save 24 inch diameter disks this way, without cracks or breakage.
bos
Brian
How about leaving them in 18-24" logs. Let them dry a year and then cut the disks. You will get end cracks but you may be able to salvage some out of the log.
Brian
Dick Coers
Pine in log form for over a year outside will not give you much to work with. It sure will be different colored, and covered with checks around the outside. The sap wood is likely to be punky in that amount of time. Then there will be the bugs to contend with. They love pine.The desire to save crosscut discs of trees has been an eternal quest, with much failure. They look great, but you are fighting the nature of the material. Nature almost always wins, or as my naturalist friend's bumper sticker says, "Nature gets last bat"
Brian
How about soaking in denatured alcohol ( not beer) or I have tried liquid soap detergent with OK success. Many wood turners use these methods to stop cracking and those 2 methods have moderate success.
Brian
Re: New Wood
I don't know of any way to cut slices off wood and dry it successfully without cracks. The plastic bag method does work but takes forever and you have to do it every day pretty reliably. It will also mold and leave colors you don't want for wood burning.
Leaving it in log form it will also crack. By far the best way if you want to save the wood is to slice it and make board, seal the ends and then try to dry those.
We turners take wood like that and turn it to 3/8" or less and let it dry and warp. Even then we don't leave the pith in. It will usually crack except in some species.
Bradford Pear is an excellent wood for woodburning but not cut as you recommended. Turning hollow vessels or bowls that are thin is the best way to get this wood ready for burning. You could slice pieces parallel to the grain instead of across the grain and make yourself some thing pieces. They will still warp and need to be flattened but it can be done.
Pine has very hard winter grain and soft summer grain. That makes it difficult to burn even straight lines. Get a smooth even grained wood like Bradford Pear, or even maple and sycamore. Cherry is good but of course not very light in color.
Re: Pentacryl
Rick L
http://www.preservation-solutions.com/pentacryl.php
http://www.preservation-solutions.com/crosscut.php
Haven't tried it on pine but it does work. PEG is outdated.
