Mixing Spray Lacquers?
This weekend was my rookie venture into HVLP spraying of lacquer. I am pleased enough with the results to wonder why I hadn't tried it earlier.
I used a satin finish. I must say, the result is really a satin finish. So many other (hand applied) satin finishes range in sheen and to my eye look more semi gloss.
I am satisfied with the satin but, given past finishes, was expecting a bit more shine. So is lacquer a product where you can mix satin with semi-gloss and get something in-between?
Thanks
Tom
Re: Mixing Spray Lacquers?
Earl Kelly
Yep. Just be careful when additional pieces are needed in that sheen. If you stir thoroughly and mix/measure precisely, replicating the sheen shouldn't be a problem.
Bill Tindall
I presume we are talking about solvent based product. In this case mixing the same brand, different luster, is not only acceptable but it is the way to get just what you want. I buy 5 gallon quantities of semigloss because it is greatly cheaper buying 5 gallons. I divide into gallons. I let the delusterant settle and decant gloss for gloss application and mix the concentrated delusterant to make a duller finish as needed. Different brands may be formulated with different solvent systems, different plasticizers and maybe even different film formers. Hence, mixing different brands might be risky.
Dick Coers
You can also just buy a can of flattening agent to add and adjust sheen. Industrial lacquer is purchased by percent of sheen. Find out what you are buying to be able to properly adjust.
Flat (1–9% gloss)
Low Sheen (10–25% gloss)
Eggshell (26–40% gloss)
Semi Gloss (41–69% gloss)
Gloss (70–89% gloss)
Thomas, I spray a lot of lacquer, I normally spray several thin coats (5 or 6). I spray the first 3 or four coats using gloss (lightly sanding with scotch pads to remove nibs etc. in between coats) then switch to satin. The more coats of satin I spray, the more of a "dull" finish I obtain. I know many people will disagree but I then wax the surface using 4-0 steel wool and either Briwax or similar, then buff out with a soft cloth. I like the surface "feel" and appearance of the wax.
Sgian Dubh
Larry, what kind of lacquer are you spraying? I ask because most spray lacquers such as pre-catalysed lacquers or acid-catalysed lacquer generally should end up with a dry film thickness of no more than about 100 microns (about 4 mil) to avoid cracking or the more severe Chinese writing fault. This usually means spraying no more than three coats with each wet coat being about 100 microns thick-- 100 microns is usually reckoned to be about the same thickness as the diameter of a head hair. If the lacquer contains 30 percent solids, then three coats will result in a dry film thickness of about 90 microns once all the 70 percent solvents have evaporated.
I've found that even with spraying thin coats it's hard to not exceed the recommended dry film thickness if I get up to four or five applications that are wet enough to allow the polish to flow out well. so I wonder how you achieve that? Perhaps you sand back hard?
I suspect the "more dull" look you are achieving through application of several coats is due to a build up of the matting silica leading to greater occlusion.
Anyway, just curious. Slainte.
Richard, I am using Behlen Qualalacq Lacquer, it is a nitrocellulose based lacquer, (not catalyzed). I'm sure the pre cat and acid-cat may be tougher and hold up for some applications that the Behlen won't but for my uses it has worked fine. One advantage is that it like shellac and can be touched up / re-coated without any problems.
Sgian Dubh
Larry, you've answered my question by saying you are spraying nitrocellulose lacquer. That stuff can be built up with multiple coats as it has the flexibility to avoid the cracking/Chinese writing faults. It can't be done with pre-cat and acid cat lacquers, et al.
Still, the dulling you report is due to the large amount of silica you're getting on in successive coats. What it's doing is getting so thick that it's starting to block light passing through the polish to a significant level. In other words it's starting to get a bit bit 'paint like'. Maybe it would be an idea to just use your sheen of choice for the final coat or two. Slainte.
Richard, I think my choice of words was wrong, I could not think of what to call a "more satin" finish so I called it "dull". I am actually doing what you advocate. The lacquer I use is in a "spray thickness" formulation as purchased. I normally thin about 50% with thinner, then spray a couple of coats. This doesn't seem to obscure the wood color or appearance but "knocks down" the high gloss. After waxing and buffing, it does give me the appearance that I like. I certainly am not a pro like you and greatly admire your work, but this does work for me. I have tried many different finishes on several species of wood. When I work with Cherry, Walnut, Mahogany and such, I really like to use very little or no stain, with the natural amber tint of the lacquer or shellac slightly toning the wood. I guess I try to avoid the commercial look of heavily stained imitation mahogany or other faked woods.
Sgian Dubh
Larry, what might be an idea is to omit the satin lacquer altogether and just use gloss. Perhaps you've already experimented, but if you haven't you might try it on a sample board.
I suggest this because you like to steel wool and wax your final application of lacquer, which in itself takes a gloss finish down a refractive index or few, depending on your vigorousness and time spent doing the job. Anyway, it was just a thought because, to be honest, I like to finish straight off the gun if I can reserving wax and steel wool for finishes that haven't levelled out as I like, or contaminants have dropped in, etc.
I do think that you could probably apply fewer, but thicker coats to get the build you want, and that could speed up your finishing time, although perhaps time isn't critical to you. I tend only to thin out by about 30- 50% for a first coat over a very coarse textured wood, eg, a red oak, simply to seal the grain. This helps prevent bubbles of air trapped in the grain from working back up through a coat applied at the normal thickness of about 100 microns-- which spoils the coat rather. After the first sealing coat I revert to normal coat thickness application sure that the bubbling up won't happen. Slainte.
