Cove cutting tips
Cove cutting tips
Cove cutting tips
Stephen Kirk
Ive got to cut coves around 3 sides of the tops of three bookcases. They're big tops, about 50" long, 18" deep and 1 1/8 thick, red oak. Since they're bigger than I like to run over the table saw, I'm thinking of routing away most of the waste in a a few passes. Then follow up with as close matching router bit as I have, then finish with scraping and sanding.
Any other ways to do this? I don't have a shaper and pushing these over a table saw blade many times for a cove cut doesn't sound like much fun.
Re: Cove cutting tips
Bob
Bob
I know of no other way to make cove. If you make a good jig that fits your table saw using the T-Slots to secure it and a top board to hold down the stock as you feed it SLOWLY through the jig you should be fine. WAY to much work the way your talking about doing is and your transitions may not match up. Here is a jig I made for rocking chair arms I got it from Hal Taylor's DVD course and it works great.
Bill Tindall
I have made moldings as you describe and it worked surprisingly fast, so long as you know how to sharpen a scraper.
John McGaw
I guess I'm not picturing your desired results correctly. If your tops are 1-1/8" think, how big to you plan to make the coves? By my figuring you probably can't be going for more than 3/4" radius and that is well within the range for a router as long as the cuts aren't too heavy. Or are you aiming for a more oval profile with a wider-than-deep-curve? Even than should be easily achievable with a heavy router in a table although the bit to manage it is rarer than the simple round profile.
Keith Newton
I'm not sure of your desired size and shape, but the fence diagonally across the table saw can take much bigger cuts, with a dado set, tilted, then feeding into the blade from the side it is tilted toward.
But there is still a lot of cleanup for a cove cut this way.
Yonak
The worst part about cove cutting is cleaning it up (sanding, scraping, etc.) Can't you do the whole thing with a router ?
William Duffield
They've been making cove and many other much more complex cornice moldings for thousands of years for architecture and for hundreds of years for fine furniture before the routah and tablesaw were invented. Sticking them using rabbet planes and hollows and rounds really takes no more time than using power tools that were not designed for the job, especially for short runs of non-standard shapes. If you needed to run hundreds of feet, a custom cutter in a shaper would make a lot of sense, but the expense of getting one made, and the lead time often is not practical.
There is a simple trick to make sure that the transitions at the miters line up. Just keep your sections in order when you are cutting and installing them.
More info can be found here on the equipment and methods needed to do it.
www.planemaker.com
http://www.msbickford.com/
http://www.acanthus.com/event/molding-planes-with-matt-bickford-4/
Lots of reputable old tool dealers sell antique molding planes in serviceable condition at much lower prices than the new ones, so don't panic at Larry Williams' and Matt Bickford's prices.
If you think cutting the rabbets by hand takes too long, it's perfectly acceptable to use a dado stack on a table saw, tilted at the spring angle of your particular cornice. While round planes are pretty much essential for cove, you can often get away with a few passes with a block plane followed by a scraper (or even sandpaper) for beads.
