A55 Smoothing Plane
Router set up question?
what? another on topic question? Irby must have been hit by lightening.
My friend in the post below asked if I had a trick way of making a router table set up repeatable. Is there a way to cut part of a set of doors, change the setup and then go back to the first setup without a lot of fiddling?
Re: Router set up question?
Kneale Brownson
Kneale Brownson
I keep the final test set-up pieces for each thickness with a label and use those to help repeating a set-up.
John in NM
I usually try to organize things so I make all the similar cuts at once, then move on to the next set up - kind of sucks to have to go back and get it just so.
However, one of the already milled parts, or a piece with a test cut can serve as a gauge block. There aren't really any tricks to it that I know of.
William Duffield
I have two routers. One mounted in a lift, the other mounted in a plate. Of course that only solves half the problem, since I still have fence adjustments to worry about.
Make 2 pieces - use 1 save 1 for set up only way
George Colonel's Workshop-Havertown PA
Good Morning Barry,
I agree with the above responses. I use a profile block from the original set up, and adjust to it with my Mast-R-Lift. Quick and accurate.
George
