Advice needed -- drilling ivory
AZ in Colorado Springs
A friend is making a replacement handle for a sword, and is using ivory. The handle will be about 4" long and 1" thick and maybe 1-1/2" wide. It requires a cavity all the way through that at one end is a 1/4" hole and at the other end is 1/4" by abuut 5/8" or 11/16".
I'm thinking that to make the cavity, we will bore a 1/4" hole all way through, and then bore a second hole, starting at the wide end, and angled to converge with the first hole at the other end -- think of a two sided angle, with the vertex at the end where a 1/4" hole is required.
The ivory (walrus tusk, in this case) doesn't appear to have any grain, but there is some sort of pith near the center of the piece we have.
My question is what are the pitfalls, if any, for boring holes in ivory? I'm thinking of using a brad point bit for both holes (if that bit is too short, I'll finish with a longer bit that I have that is not brad point), and I'll make a guide block as a visual aid for getting the correct angle on the second hole.
Also, the wide end of the cavity will need to be squared up. Any problems using a plain old bench chisel from the borg for that?
Thanks in advance
Andy
