We value your privacy.
Thank you for taking the time to look at my post. My father in law owns a saw mill and he cut me a white oak slab about 4 inches thick. I gave it to my best man as a gift so he can use it as a bar top in his cabin.
How do I protect and stain after we sand and level this slab?
Any useful tips are welcome as we have never attempted anything like this before.
That's quite a slab. You didn't mention whether this has been dried. Oak is one of the more difficult woods to dry properly without checking etc. Air drying would take probably 3 to 5 years in my estimation. If it is not dry and you try to install it, the slab will shrink, and likely crack or split depending on the ambient humidity and temperature conditions. My first inclination would be to discuss this with your FIL and see if he has advice about a possible kiln drying supplier. After it is properly dried, you can either hand plane the slab or depending on the size, possibly take it to a lumber supplier that has a commercial planer or large belt sander to flatten and sand the surfaces. It is not a beginner project to do this with hand tools. After it is sanded there are many good finishes that could be used - if it is to be used as a counter top you would want a durable finish such as polyurethane or similar.
I have dried a lot of lumber. It is correct that oak is difficult to dry without cracking it. It needs to be put somewhere out of the sun and rain where it will not get too hot, yet get good air circulation. For this case the ends need to be sealed with paint or wax, PROMPTLY. It will be dry enough within a year if the air circulation is good. Do not attempt to kiln dry it for it will be ruined. Nobody runs a kiln under conditions suitable for 4" thick oak.
If you ever get it dry the easiest thing to do would be to take it to a cabinet shop that has a wide belt sander and pay them to sand it smooth. You might get them to finish it while they are at it.
