Router table build allmost done
Bob
Bob
I am building a new router table 49" X 25" with 3/4" & 1/4 T=tracks, 6 draws a shelf and lift with dust ports. Here is what I have so far.
(I guess you can only post one photo and no uploads to the sete here :(
Re: Router table build allmost done
William Duffield
There are two ways to post pictures, and you can use both of them in a single post. You can post one image from a url on the web, using the "Optional Image URL" box. You can also post as many images as you want (100 Kb max, each) from your local storage, using the Choose File button. Those images are inserted in your text, wherever your cursor is sitting when you push the button. When you hit the Choose File button, you get a window that you use to search through your file system for the picture you want to insert.
...but you must be registered
The fact that your name shows up in Black, not linked to your valid profile, tells me that something is amiss with the way you typed your name lat time you posted. The fact that you got an invalid password error is because your username doesn't jibe with the profile we have on file for your e-mail address. You need to go to Set Preferences and check to see that your username and e-mail are current, and then save the changes.
As soon as you are recognized as a member, you will be able to post directly from your computer.
E-mail me if you have problems.
Ellis Walentine, Host
Bob
Re: ...but you must be registered
bob
OK but is seems strange I have the problem even when it knows who I am, Ill give it a try thanks.
William Duffield
Oh, that's a relief. I thought he was talking to me, and I didn't touch a thing! :D
