Plywood grain and shelves question?
Most of the time when I use plywood for shelves, I usually rip the plywood and then crosscut it.
I have to make a number of shelves for the prop room of the playhouse. I figured on ripping 2 x 4 to get "2 x 2" to act as support for the shelves. I was going to assemble the 2 x 2 into "figure 8s" and cover it with a piece of 1/2" plywood 4' x 15 7/8". I was going to lag or screw the 2 x 2 onto four 2 x 4 uprights.
This got me to thinking - why rip? Why not just crosscut the 4 x 8 sheet of plywood? I would still end up with six shelves per piece of plywood. The plywood is fully supported by the 2 x 2 frame in any case.
Any good reason not to do it this way?
Re: Plywood grain and shelves question?
Go for it
paul in AZ
I've not worried about that unless there was an aesthetic reason for whatever grain orientation of the top layer of the plywood looked best.
Plywood is stiffest in the "long grain" direction of the outer layers (and significantly stiffer that way than "cross grain")*. I guess a lot depends on what props you're putting on there. If mainly light objects, I'd go for it; if they're heavier, I'd stick with the extra work of the long-grain shelves.
Also, if you have a choice, go for a higher ply count - some of the cheap 1/2" ply is three ply, but five ply makes a huge difference in stiffness.
*Our attic floor is composed of 2 foot wide sections of 1/2" ply, laid long-grain across the 16" on center joists. Works fine, but I know from experience that, if I tried it the other way, I'd be making foot sculptures in the plaster of the ceiling below.
NickinMass
I can't say I've noticed any difference in stiffness with hardwood plywood, and I have made some shelves that had the grain running the "wrong" way with no problems (granted, with good quality 3/4" hardwood ply). Softwood ply is a totally different story - 1/2" CDX is scary flexible "across" the grain.
No problem cutting it the other way. I can rip it to width with the table saw and cut it to length with the 7 1/4" saw.
Re: Elements vs panels.
TomD
Plywood is structurally divided into elements and panels. A shelf is an element, a trap door is a panel. Sounds as though your framed plywood piece is a panel. For panels grain orientation is to the shortest span.
So imagine you are at the job site. You want to build a little bridge. if you are forced to use plywood you absolutely want the long grain going the length of the bridge. It is an element, or a beam. But if you have two wooden spars, and the plywood is going to be nailed on as decking, you want the spars to span the gap, and you want to configure the long grain of the plywood so that it spans the gap between the spars, and you want to nail the perimeter.
Another example would be I joist. The webs should have grain oriented to span the two flanges, not to carry the longi loads of the whole joist.
Ply may come in balanced, form, like some marine or aircraft ply that uses a lot of very thin lams, the idea is that it will be ideal for panels being virtually equal in strength and stiffness, 0/90. However, even in that case there is still a major difference in grain aligned pieces or not. It is just closer to the panel ideal. Of course, when making elements, unbalanced ply, or other more biased products still, are preferred because these will require maximum capability in a single direction, where even solid wood might be necessary.
