Table Saw RPM
Woodie49
Does anyone know what the blade RPM should be for a table saw? I have a 3450RPM motor.
Thanks
Table Saw RPM
Woodie49
Thanks
Re: Table Saw RPM
TomD
What you want is a surface feet per minute number. This is the speed at the blade tooth tip, which varies depending on material being cut, and the amount of material being cut. It varies by the blade size and type, and whatever you come up with will need to be within the operating envelope of the saw and blade. Feed is actually the starting point, but since that is done by hand, by most of us, it is generally not discussed.
SF, to get say 10 000, with a 12 inch blade that is pretty much 3 feet in circumpherence, and three goes into 10 000 3300 times approx, so that is your rpm for that blade and SF figure. You can just do a head calc, the inputs are the important part, calculating to several places has less effect. I have a 2 in book of SF for bansaws, literally from patries and cardboard, to steels. But something in the 3600 range for a 10 inch blade is probably OK as a guidepost.
Re: 10" Unisaw blade is 4000 RPM
New Delta Unisaw is 4300 rpm blade speed
Re: Table Saw RPM
Howard Acheson
For 10" saws, the blade RPM is between 3000 RPM and 3800 RPM.
Laden or unladen?
Jason Roehl in Lafayette, IN
African or European table sawllow?
Jason
Re: Table Saw RPM
Direct drive would be 3450 rpm. Other than that go by the pulley size. I.E. if your pulley on your motor is 4" (inner size) and your pulley on your arbor is 5" (inner size) - then 5/4 x 3450 = 4300 (approximately).
Re: Bassackwards
Al Stokka - Cambridge, Iowa
JL,
You got it bassackwards. In your example the arbor would be turning 2857 RPM.
Y'all want the smaller sheave on the arbor to run it faster than the 3450 motor.
Al
SPROI-OI-OI-OI-OING!!!
Henry Higginbotham
You have to know these things when you're a king, you know?
