REAL MILK PAINT
Wood Cracking
Wood Cracking
Wood Cracking
Johnny Narron
I just cut a downed pine tree into 1 1/2" discs for pyrography projects. I've read to use Polyethylene glycol (PEG) in reading further I've seen that miralax has the same ingredient, can I use it to make a PEG solution and if so how do I mix it and how long do I soak the wood?
Re: Wood Cracking
Re: Wood Cracking
I don't know if there are versions of polyethylene glycol. Presumably Miralax uses a food-safe version, which is likely to be more expensive than a regular version.
I'd contact local chemical supply houses and see if they carry PEG; or see if any of the woodturning catalog houses offer it.
Re: Wood Cracking
Dale Lenz
Agree
Dale Lenz
Start off with the Real Thing, PEG-1000. After using and getting use to PEG-1000, if you want to change things up, go for it. Let us know how your mileage goes.
Re: Wood Cracking
Rick L
Re: Pentacryl  *LINK*
Rick L
Use pentacryl...I've seen it keep cross cut slabs from splitting and you can put a finish on the slab unlike PEG which has a wax like coating.
Peg is obsolete
