Re: Project pix *LINK*
Dave Paine
Point and click skills - plus some software.
Ideally the piece is photographed on a flat white background. If so little processing is needed.
If the piece is not on a white background, then you need software which will allow "masking" the item which can then be copied to a new file.
Masking can be manual - you essentially draw around the outline. The cutting board example would be easy. People, animals, plants etc. are not so easy due to many edges.
The more advanced software will allow you to specify a colour and then the software will mask similar colours. Sounds easy, but even your cutting board example is not a single colour. Many shades of orange/brown.
Most software will allow you to edit the mask, and so you can manually add or move areas.
The software is normally a graphics program, such as Photo-Shop or Corel Draw or PaintShop Pro. The latter is normally the least expensive. I see Corel has now purchased Paint Shop Pro. The program is still inexpensive. $50. See link.
In PaintShop Pro, they appear to be calling their masking feature "Smart Carver" and they have trademarked the name.
http://www.corel.com/corel/product/index.jsp?pid=prod4220093&storeKey=us&trkid=NASEMGglDM&gclid=CMCHyvSosLECFYio4AoduwUAAg#power
