We value your privacy.
My craftsman radial arm saw motor quit about the time I decided to convert to a sliding compound miter saw. What I would like to know does anyone have any ideas on the possibility of converting the saw structure to a overhead router?
the other day. This will give you at least a general idea, too bad he didn't take more pictures . Was thinking about doing this myself, but found an OAR at our local Re-Store.
back in the early seventies, I bought a RAS which had a mandrel which could be used as a over-arm router. I used it a few times, and came closer to loosing a hand than anything I ever have used since. In fact, I don't know how it missed. I can still recall holding them up in front of my face to see if they were still attached, and made a promise to both of them never to try that again.
The inherent flaw, is that there are too many articulation points between the work, back around to the motor and cutter, which will allow enough play for the cutter to set up a harmonic vibration, which destroys any hope of precision, and lead to the bit taking unexpected seizure of the work.
Then add to that, the cutter is on the level with your hands, which can be drawn into the cutter, if you are feeding it through the bit. It is much safer to just use a router which has two handles to hold onto, and run it over the material, or put it under a table.
Agree with Keith. I set up an old radial arm as a dedicated dado machine, but with a dado blade. It is difficult enough to handle. I am currently routing a deep dado using a plunge router and a special purpose base that traps the work and keeps the dado aligned. The cutting action is decidedly different depending on the direction I am moving the router. FWIW I have considerable routing experience, as people who know me can tell you. I made it is special study to understand the dynamics of what is going on. The danger of using a radial arm ought not to be minimized. Overarm routers have a guide on the top and the bit extending up through the table for a reason. It is to protect you from forces you cannot anticipate. Please be careful. Keep safe. Find another way. No one wants to rename you Stumpy.
