Test, Test, Test
Aside from adhesion issues (shouldn't be a big problem if you scuff sand as mentioned, suggest finer grits 220-320) different waterborne clears will have different refractive properties in the final film, not to mention slight tints. Some will push your black into the cooler blue range while others will trend to the warmer ambers. What you see in the can won't answer the question because it's the refractive structure of the final film that determines the result.
Paint some scrap black, then apply your clear(s) in several applications to see what you'll get.
I've seen some lovely finishes where a black was used and then overcoated with clears; very deep and rich like automotive paints. You do need a very even surface on the black because the clear film will act something like a magnifier for things like brush strokes or lap marks in the base coat.
