We value your privacy.
I have a Delta contractor tablesaw. I just found out that when I tilt the blade, the blade will no longer be parallel to the table insert slot. The far edge of the blade is closer to the slot than the near edge. As I keep on tilting the blade, the far edge will eventually press on the right edge of insert slot. It acts as if the far end of the trunnion is not tilting in sync with the near end.
I know that the blade is parallel to the fence at 90 degree. What can cause this problem?
What you describe is a not-so-well known condition that arises when the blade/trunnion assembly (on a contractor's saw) or the table of a cabinet-type saw slopes forward or backward. The solution is to put shims or shim washers between the trunnion assembly and the top (on a contractor's saw) or between the cabinet and the top of a cabinet saw.
If the front is too high, the back of the blade rubs on the left side of the cut and vice versa.
The trick to supertuning, regardless of what kind of saw you have, is to adjust the table slope so that it is properly adjusted to the blade. On a cabinet saw, this involves using shims or shim washers where the top bolts to the base. On a contractor's saw, it involves shimming the fore or aft connections of the trunnion assembly to the top.
The simplest way I know to measure this slope and figure out how your shim thickness is to follow a procedure we outlined a long time ago in American Woodworker magazine. (Issue #43, Feb. '95) Basically, you need a good reference plate or an alignment bar to put on your saw's arbor. Then, you need a caliper and a small metal block so you can measure the distance from the left miter gauge slot to the blade or alignment bar, at both the front and rear positions. You need to shim the top (or the trunnion assembly on a contractor's saw) until the front and rear measurements are the same.
I can't seem to find a copy of that issue online. Google Books used to have them all archived, but something must have happened to them, probably copyright protests. If you can't lay your hands on a copy, let me know.
Yes, it was nice to meet you at the AAW symposium. I was actually surprised that you remembered my name.
I am not trying to supertune my tablesaw. I am trying to correct a problem of cutting bevel.
I did some measurement and I found that the back of the blade is 0.055" further than the front referencing the left miter slot. This is the reason why it touches the right edge of the insert slot when I tilt the blade (right-tiled saw). If I try a cut a beveled piece, the piece will bind between the blade and the fence and it will not be the same width.
Based on my research, this means that the table top is lower in the front than the back. Adjusting the height of the top is very challenging on a contractor saw. It is especially challenging when the front needs to be shimmed as the access is very limited. I am hoping that someone having the experience with this will share with me the how-to.
In any case, I will sleep on it for a day or two to see whether I can gather the necessary information on how to correct the problem. It may comes to that I will have to live with a tablesaw which cannot do bevel cut. I rarely do bevel cut so it is not a big loss.
That slope problem is what supertuning is all about, vs regular tuning which is done by squaring the table to the blade. Supertuning will adjust your table's slope relative to the blade so that the blade tracks accurately through the pass.
On a contractor's saw, the fix is to put shims between the trunnions and the table where needed.
There are two set screws right in front of the float and they accessible from the top. These screws are right on top of the front trunnion so they can be used to push down the front trunnion after the two holding screws are loosen. This will raise the top. I will try this tomorrow morning to see whether I can solve this alignment problem.
And it is probably me, but I think your second paragraph should be the opposite.
Starry, besides the shimming up and down, there may need to be some general side to side adjustments, to clear that back edge rubbing.
One little tip that i use to help figure these things out, is to exadurate the situation in your mind. For instantce, imagine that if you were feeding from far too low onto the blade. After the front if the blade has made its cut, the wood etween the fence would be cutting on the way up from under the table.
Of course while you are making the adjustments, if you flip it over to ease the work, everything is backwards, so good luck.
Rather than trying to go by measurements from the slots, I would make sample cuts, and examine the tooth marks on both sides of the kerf. Your goal is to not have any or much tooth marks on either side of the kerf, when 45 or 90.
Dyslexia isn't out of the question, but the point is that you want the front and back of the blade to both be parallel to the miter gauge slot when the blade is tilted. Different saws require different shimming methods in order to adjust this relationship of the blade to the table top. On a contractor's saw, the blade/trunnion assembly is actually bolted to the top, so the shims need to go under either the front or back bolts depending on whether the front or back of the blade is closer to the miter gauge slot. On a cabinet saw, the top is bolted to the cabinet, as is the blade/trunnion assembly, so the shims need to go between the top and the cabinet.
Years ago I solved the same problem on my Delta contractors saw guided by the article that Ellis refers to. I have the magazine tucked away but I'm out of town for a week. If you can't find a copy of it send me a note and I'll get you a copy when I return.
For contractor type saws there is a significant area of alignment that is not detailed in most magazine tune-up articles. It is ensuring that the trunnion bars are exactly in the same plane. Proper adjustment affects bevel cuts and is indicated when there is burning when making bevel cuts. Here are the corrective steps that were at one time posted on the Delta website.
First go through the alignment process following the steps in the attachment below.
To check whether the trunnions need to be adjusted, tilt your blade fully to the 45 degree position until you get to the 45 degree stop. Then crank the blade back to the 90 degree upright position. Now again check the parallelism of the blade to the miter slot. If the blade is still parallel to the miter slot, declare victory. If not, follow the process below from Delta to adjust them. The process is the same for all Contractor Saws or Hybrids that have the trunnion assembly hanging from the table.
1. Remove the saw blade being sure it was at it fullest height.
2. Place a flat plate (or similar flat object) on top of the two tie-bars. (The size of the plate should be at least 6" by 8", and the flatter the better. A pane of glass works well.) Depress one corner of the plate and if it rocks, the tie-bars are not parallel. This must be corrected as it will affect the alignment of the blade.
3. Loosen the tie-bar locknuts located at the rear of the saw.
4. Grasp the motor bracket and move it left and/or right. Check the rocking of the flat plate and when it can no longer rock, the tie-bars are parallel...re-tighten the locknuts.
5. Remove the flat plate and re-install the saw blade.
6. Again perform the parallelism alignment process.
7. Before tightening the rear trunnion bolts, push forward on the rear trunnion bracket to allow the undercarriage to snugly fit between the two trunnions.
ATTACHMENT--BASIC TABLE SAW ALIGNMENT
Here is the low tech, low cost way to align a tablesaw that I learned maybe forty years ago and use to teach to my students.
Make 3/4 x 3/4 x 12" hardwood stick. Drill a hole somewhat centered in one end and insert a brass #8 x 1" round head fine thread machine screw about half way. UNPLUG THE SAW. Raise the blade completely up. Clamp this board in your miter gauge (if you determine that there is some slop in your slot to miter gauge, use a playing card to take up the slop) so the screw head just about touches the blade at the front. Now rotate the blade by hand and determine which tooth is the closest. Adjust the screw in or out until it just touches this tooth. Mark this tooth. Rotate the blade so the tooth is now at the back of the table and move the miter gauge/stick assembly to the back and see if it touches the marked tooth to the same extent. If it doesn't, adjust the trunnion (if a contractor saw) or the tabletop (if a cabinet saw) until it does.
For a contractor saw, first use a small c-clamp on the rear trunnion and cradle to keep the assembly from moving. Then loosen the two rear trunnion bolts and one front trunnion bolt. Slightly loosen the other front trunnion bolt and use a stick to tap the trunnion until the blade and screw lightly touch. The blade does not move directly around the center so you will need to repeatedly go back to the front of the blade, readjust the screw, and then again measure the back. Be sure to check after tightening the trunnion as the trunnion frequently moves when being tightened.
For cabinet saws, loosen the bolts that hold the tabletop and tap one corner until things come into alignment.
The same adjustment gauge can be used to set the fence parallel to the miter slot. Slide the miter gauge to the front of the table and move the fence over to the screw head and insert a playing card between the screw head and the fence just so you can move the card as it touches both the fence and the screw head. Now move the miter gauge to the back of the table and see if you have the same feel when you insert the card. I like my fence absolutely parallel--if you want to have a slight opening to the fence, you can easily estimate the opening by adding a thickness of paper to the card.
I always show my students with a dial gauge that their adjustments are within .001 - .002.
You can also use the same gauge to measure blade runout by using a $5.00 feeler gauge.
Finally, after you are satisfied with the above adjustments, check the position of the splitter to make sure it is exactly in line with the blade.
Bottom line, there is no need to spend more than the $0.05 for the brass screw.
The tie-bars are parallel. The blade is straight at 90 degree with a back to front difference of 0.002. Test cut measured with a caliper confirms the cut is straight.
I think the problem is the table is lower at the front. There are two set screws right on the top of the front trunnion possibly for making adjustment to the high of the table. I can see that if I loosen up the front trunnion screws, these two set screws can jack up the table in a very control manner.
I still own my first one, bought around 1973-75, and recall dealing with this same problem, as well as 3 unisaws and One PM 72.
Ellis, I have no doubt that you know how it is done, but it seemed something g got lost in translation, when up and down change when the saw is flipped over.
Back when my little 9" contractor saw was my only T-saw, I really needed more power than the one hp motor could deliver. Rather than sticking with a TEFC, I bought a Leeson 2hp open frame, then turned the motor pulley so the hub was out, and the pulley was close to the frame, to keep the other end below the top when tilted to 45. Yep, that made a big difference on those days spent busting down material, back when I was a job site carpenter.
