We value your privacy.
I'm making a jig to do some fluting and "flatting" on some legs with my router. The legs will be turned first and then I'll take the router to them. I would like a bolt (3/8" or so) with a pointed end to act as a "center". Yes, I have a grinder or two. I even have a Wolverine jig for my grinder. I just was wondering if anybody sold bolts with pointed ends before I "sharpened" a couple of bolts.
I sharpen them all the time for various uses. I'm not sure how true they run but they certainly seem true. I chuck them up in my drill and run the drill while moving the steel across my grinder. I've done really long ones for making scratch awls that have a long taper to a very sharp point, and shorter 3/8" and 1/4" that have fairly short tapers. these are used as markers when pushed through boards that have holes drilled in them.
I've always just done such work on the lath -- it is already a precise no-effort supporting structure. All you need to do is to rig a support to allow you to run your router back and forth and it really takes no more than a piece of laminate-covered MDF secured on top of the lathe ways and an "L" support for the router which supports it horizontally with the center of rotation at the proper level above the ways. I've been meaning to make a permanent jig for this for years but it is so quick to do that I've just jury rigged something whenever I needed it.
If you have a scroll chuck for your lathe, you might be able to chuck the bolt in it by the head, very carefully aligned, and grind the bolt to a point with an angle grinder, while the lathe is turning. That's how I taper the points on awls. Warning: Sweep up under the lathe first. Lots of sparks. If you can't get the hex head aligned in the chuck, just cut it off, then chuck the headless bolt, and when you're done, use a hacksaw to cut a screwdriver slot where the head was.
When I want to flute or reed a column, I keep the column between the lathe centers that I used when I turned it, and build a jig that holds a trim router horizontally at center height, and that slides on the lathe bed. My lathe does have an indexing head, so I can lock it to keep it from rotating at any angle I need. The only problem I've had with this arrangement is that the weight of the router want to tip the sled off the lathe bed. It helps to extend the sled beyond the far side of the lathe bed and add a counterweight.
I have a couple jigs that use said bolts to locate screw holes for later drilling. Mine were all made by chucking a allen head cap screw in a machine lathe and sharpening the rotating bolt end with an angle grinder. Never had much luck getting them really symmetrical any other way.
On some chucks, there is enough clearance behind the jaws for the bolt head. This presumes you have spigot jaws or jaws that close enough to hold the bolt. Or you could bore a centered hole in a piece of wood big enough to chuck. Make a recess in the back for the bolt head. Either way, chuck away , turn on the lathe and grind a point.
I have just chucked a piece of threaded rod into a drill press, and sharpened the spinning rod with a file or stone. This avoids the problem of the head of the bolt getting in the way, and you can lock a couple of nuts against one another to mimic the head. If your chuck has clearance for the head, that would be simplest.
