unbending a atwist in BB ply
Carol
This piece was flat. The plywood has been standing against a flat wall, not stored twisted in any way. Further I've had it for nearly a year in Arizona, moved it here a few months ago. It is 13x32 and it has twisted about 1/4" out of flat. It is super dry here - single digit humidity every day! I cut a second piece. Same problem. A new sheet is well over a hundred miles away. This is to be a shelf with ledgers, which did not pull it flat on the first piece.
What are my chances of soaking them, clamping them flat and having them stay reasonably flat? There are adjustable shelves, so no dado to lock them into. My thought was to clamp them flat and lay a well soak towel on the top. Let that dry, then flip it over and repeat. It would dry in 12 hours easy. If that looked like it wold be working, I could repeat it until it does. This shlef will be painted and eventually live in an air conditioned home in Yuma with others like it with goodness only knows what stacked on it.
Any thoughts?
