We value your privacy.
A better way to think of it is the nut or collet loosens in the direction of rotation thus automatically tightening when running. A shaper typically uses a double nut to allow for dual direction.
Easy way to explain - imagine holding the grinding wheel arbor in your hand and rotate the motor shaft CCW - the arbor should then screw on the shaft and tighten. (If you hold a standard RH bolt in your left hand and put a nut up to it and rotate the bolt CCW it will screw into the bolt.)
