Cutting 1 3/8" x46" boards
This is actually a turning project but I think the flat side will be more likely to answer this. I'm making a stave construction project. Each stave is 46" long, 1 3/8" on one end and 1/2" on the other end. I have to cut 32 of these staves.
I've built my taper jig and testing it with Furring strips. So far it's looking good. I really love my new Forest blade I bought for this project.
Here's my question. I can't buy pre cut 1 3/8" or slightly wider maple pieces so I'll have to cut them from wider boards. I've had problems before when doing this with the strips warping. Anyone have any ideas if it's possible to pick wood that is less likely to do this. It's obviously internal stresses but I don't now how to predict it.
Re: Cutting 1 3/8" x46" boards
Dale Lenz
AD boards
Dale Lenz
I do some of this, not your length. I AD all of my lumber myself and 95% of the time don't have problems. Sound like to me it could be built in kiln drying stress, IE the lumber was not conditioned properly. To my knowledge no way of telling if this will happen by looking at a board, even qtr. sawn lumber may warp when resawing if there is interal stress.
not that easy a decision
Bill Tindall
Drying stress can occur when lumber is dried through the range where it shrinks- about 25 to 0 per cent moisture. The likelihood of improper drying in this range is much greater if the lumber is left out to dry as it may than if it is dried under precisely controlled conditions in a pre-drier and then kiln as it will be in most drying operations now days. If anyone is buying lumber that routinely has stress you need to change supplier. Buyers big enough to count would not tolerate lumber with drying stress, so it will be rare to encounter it when dealing with well managed driers.
Stress can also result from the way the tree grows. No easy way to cure this problem.
Moses Yoder
Moses Yoder
I would cut them oversize; the amount will depend on how much they are bowing. Then make one edge straight on the jointer, and rip the othe side to size or just taper it, depending on what your project calls for.
Re: Agree with Moses
One additional tip - I have had boards warp overnight after cutting - possibly due to moisture adsorption?? I would cut as Moses said then let them set at least overnight before finish cutting to size.
Joseph Mulherin, sr
I was cutting some laminations for my chairs and noticed this warping also. So, after cutting about 12 of them I bound them together and placed under a board with a concrete block on top for a few days. This did the trick and gluing up the lams came out fine. The wood came from HD, thought to be kiln dried, but evidently the moisture in the air changed, so I let the cuts rest for a few days before gluing up.
would air dried be better.
I have a friend (Alf Sharp) who is now selling air dried lumber. I will try to call Alf Tomorrow and get his opinion. He lives about 40 miles from me and has a big warehouse full of air dried lumber. Seems to me there would less stress in this wood unless the tree had internal stress.
Dale Lenz
Re: would air dried be better.
Dale Lenz
John AD vs. KD has all to do with the person in charge. Both type of treated lumber works great, AD & KD, IF, it was done properly! Many folks around here do a bad job of AD. Nearest kiln is 2 hours from here, as far as I know. I try to purchase my green lumber the same day the tree was felled. There's a saying in wood drying: It's what's up front that counts. That is how you treat the lumber during the first part of the drying phase. Anyway, if you believe in your friend with the AD lumber, I'd try it. Will need to dry the AD lumber further down for furniture use. I strip stack my AD lumber in my shop and it dries down below 10% before I put it up in my lumber loft. When using AD lumber obviously, you need to keep a lumber supply of hand so your not waiting for the AD to drop MC down. Just something I've learned to do.
Good luck.
why do you think so?
Bill Tindall
"Seems to me there would less stress in this wood"
Stuart Johnson
John, Have you considered laminating MDF? This would eliminate any warping and bowing issues.
I'm going to turn this behemoth so it needs to be solid limber, otherwise I would definitely consider MDF with a laminate.
Re: would air dried be better. *LINK*
Dale Alf is a high end furniture maker and really knows wood. The Air Dried wood that he has was done by a man who simply cut and collected wood over a 20 year period. Many of the furniture guys in the middle Tennessee guild have use this wood and like it. I've left a message for Alf this morning and hopefully will hear from him before the day is out.
By the way that's my photo of the piece on his home page. I'll miss shooting for Alf. That was one of the fun parts of my job. However I'm really enjoying getting to spend all day in the shop now which was a rarity before I was retired.
http://www.alfredsharp.com/
Stuart Johnson
I knew that but got lost in the warping and bowing. You don't have a lot of time to get it done if you're going to make it in time for S.W.A.T.
What I would do,
Keith Newton
Is cut about 10 more parts than you need, and toss the worse ones.
However, I would look for lumber which came from well outside the juvenile zone. The flatter the arc of annual rings as viewed from the end-grain, usually helps. Also, look for any areas with a duller luster than the rest, or if it is in the rough, where the saw produced stringy or fuzzy surface, which indicates reactionary wood.
Beyond cutting the tappers, how do you plan to cut the bevels and handle the glue-up? That is a lot trickier than the cutting.
Thanks Keith-here's a look
Some good ideas from this group as well as the turning group. I plan to rough to do it in stages which unfortunately will really slow me down. I think I'll cut the strips and let them set and then cut the tapers oversize. Let them set for a few days and do whatever they will do. Then go back and cut the final size. Hopefully that will give me some good straight tapers to deal with.
I cut them by making a jig for the saw that holds the boards at the proper taper angle. The saw blade was then set for 84.4 degrees.
I tried lots of things for glue up. The worse problems seems to be the wood slipping up or down in thickness. I came up with this jig that is going to be further modified. The 2 boards along the sides are adjusted until there is a slight gap at the top of the joint and bottom is held together. I'm going to build a clamp to go over the top using more all thread rod. This will push the boards down to close the gap at the joint and add pressure. I'm going to do it in pairs starting of course with 2, then 4 then 8. That will be slower but should allow me to adjust the boards more accurately and take a lot of stress off me in the glue up. It will also allow me to pick the whole jig up and clean off the glue on the inside. The outside will be turned so that's not a problem. You can see that I have half the circle already glued up. It's on the floor on the right.
I wish I could have talked with you, *LINK*
Keith Newton
before you got this far. I had a suggestion which I think you might like.
When I made the piece below, I ran a half round on one edge, and a matching radius flute on the other. No matter how many parts there are, the edges always match, like a ball in socket. You are probably familiar with the strip plank canoe method.
Epoxy was my choice of adhesive, which gives plenty of open assembly time, and doesn't need much clamp pressure. Unless my shop is really hot, I have about 1 hour of open time, longer in cool weather. I thicken with colloidal silica, and wood dust for color if I need it dark. You want it thick as catsup for a project like this to keep it from running out before it kicks.
For the project below, I made a clamping fixture which allowed 1/3 of the circle, or 120º arcs, but I think it would be easy to just glue the whole circle up at once using rings to just push down from the small end until they tightened. Back to my clamp jig, there were three arcs fastened to board to keep them the right distance apart relative to their arc diameter.
These stations were like a C laying on its back, and a tab was left on one end of each, to push the parts against. Then a hole drilled somewhat back from the opposite end, gives a place for the clamp to push against the parts from the other side.
Then the next problem, which I think you probably have already found, is the middle parts wanting to slip out the wide end as the pressure it applied, so there must be an end stop to prevent that from happening.
However, for the full circle glue-up, I would make a fixture which had a big circle on the bottom, with a small one on top, separated by a pipe, which might as well be a pipe clamp to hole the bottom end-stop, once the parts are all in place and the pressure is applied from concentric rings which slide down from the top and tighten the parts where ever they happen to match the parts.
Just to try to clear this up. The assembly fixture would be vertical with the small end on top. Each stave would lean into the top held by gravity, but there might need to be an outside ring to keep them in place while each is added. These epoxy lubricated parts are very slippery.
Sorry for going on so long, but I know you like to do multiples, and if you care about making money, it is all about time.
Then,,,,,, I know you are a great turner, and I don't share much over there, but the last long straight tapered legs for some tables I made, my helper who had never turned anything, was able to turn perfectly straight tapered legs in 5 minutes each, sanded in 10 more, with the first coat of finish applied. I think he did 24 his first day, with only about 4 culls, before he learned how to overcome.
http://www.flickr.com/photos/7391658@N03/sets/72157630034448404/
Re: I wish I could have talked with you,
Keith The more I think about this the more I think it's the way to go. since I'm going to turn it I'll have to have a bottom and top anyway. Screwing the pieces to a bottom and top will also solve the problem of how to hold the door in place while it's turned. I can also fine tune the last stave just in case my measurements were off. 32 pieces doesn't leave a lot of error. I think I can use pocket screws so they won't show on the inside. They will be covered by the Walnut bottom and won't show.
Thanks big time for the advice.
I'm not sure I understand,
Keith Newton
When you stated,"The more I think about this the more I think it's the way to go."
Are you are saying you like what I am suggesting, or that you are going with the method you had chosen. the It's, leaves me hanging. If you are willing to try what I'm trying to guide you toward, get back to me, and I will try to do some sketches to clear the fog.
Re: I'm not sure I understand,
Keith I like your idea and will use it or at least something very similar. Attaching the wood to discs is the way to go.
Well, not exactly.
Keith Newton
They need to be guided into position by the forms or stations, but if you try to attach them, that might prevent them from coming together.
I just turned in, so I can get out to the lake in the morning by daybreak to finish some boat-work. It is too hot out there by mid-morning. I'll do some sketches when I get back.
I have added a couple of pics to flicker *LINK*
Keith Newton
Here is a drawing of how each station should look. Of course, you have already learned that the bottom one on the wide end needs to have a solid bottom, to keep the middle parts from slipping out due to the wedge shape.
I would also like to state again that one benefit of doing one fluted edge, and one rounded one, is that there is no worry about the angle being off a little. Also, if a few are bowed in or out, they get funneled into alignment. Which may not seem like much, until you consider that you could probably get away with three stations with the bead in cove. But with flat angles, the parts are subject to wedging forces outward between stations, so you may need more in between.
Also, Over on the turning forum, it appears that you were using yellow glue. I would encourage you to use epoxy here,
I guarantee I could make a fixture that stood on end which would allow a full 360 glue-up, using epoxy, flute and bead, with rings which slid down over the works once they were all in place.
The bottom endplate would be like a donut with a mortise for the ends to rest in, and all the other rings would pull down against it. Once they were all pulled tight, it would lift off the holding fixture, so you could clean the glue from the inside.
http://www.flickr.com/photos/7391658@N03/7606121944/in/set-72157630034448404
Jig OK - if you don't . . .
charlie belden
have the squeeze out glue your work to the jig, DAMHIKT. And you better be able to see BOTH sides of the joints to insured each joint is actually closed - on side many look find - but the other side may be open.
Hide glue for a longer set time, rubber bands that let you adjust tension inside and outside - working with pairs of staves. When all the pairs glue has set, repeat glueing and joining pairs of pairs. All the while, you can see both sides of each joint being glued to make sure the joint IS closed,
Oh, and the rubber bands can be stored in a drawer or ziplok bag and are reusable. With jigs, you have to have a place to keep them - or dispose of them
Packing tape makes a good barrier
Keith Newton
To keep from sticking to the jig.
The outside gets turned away, so squeeze out is not an issue there. And I prefinished the inside before even milling the bead and flute, so cleaning up the inside was not hard either, while it was laying there face up on the bench. The epoxy I use may take an hour before it is hard as leather, which is the easiest time to clean-up the squeeze-out.
The beautiful thing about rounding one edge and fluting the other, is that cutting a perfect angle is not an issue. I think John mentioned 32 staves, he could probably use 64, or more with the same parts. It is like the bones in your body, they are made for a big range of angles, while still fitting.
I suppose hide glue would work, but I always have several gallons of epoxy on hand, along with more than a lifetime supply of fillers.
