Does anyone here use Bag Dog tools?
AZ in Colorado Springs
I've seen their demo a couple of times at the woodworks show, and saw their ad again recently on a DVD. The tools look pricey (even at discounted show prices) but they also seem to be able to cut through just about anything. Reminds of the kitchen knives they used to advertise on TV that could cut open a soup can then cleanly slice a tomato.
Re: Does anyone here use Bag Dog tools?
Henry Higginbotham
Assuming you mean Bad Dog, I bought some of their abrasive discs one year. I mounted them, using their hardware, on the same HP and speed motor they were using for demo, and wore one disc out without ever cutting through a piece of pipe. I confronted them about it at the next year's show and they disavowed any knowledge of that product. I'd rather have random junk from a flea market.
If you mean Bad Dog tools...
Dave Paine
I purchased their drills at a WW show some years ago.
One of the drills is bent. I manage to forget to take it with me at the subsequent shows I visited. They claim they will replace......
The demo at the show looked impressive.
To be honest I have not used the set much. I tend to use my normal twist drills, since I drill wood most of the time.
The last time I used a Bad Dog bit on metal it did not seem to be cutting. I then read the instructions again and saw that the bits are supposed to be run at high speed. I changed the drill to high speed range and it cut better. Still was not as easy as it appeared at the show.
I would not be likely to purchase this set again.
Thanks for the replies
No matter how many times you proofread, the simple errors get through ("Bag Dog").
I was just curious about how their tools perform away from the show.
