Anybody tried a Rockwell Versacut Mini circ saw?
Rockwell has come out with a 3 3/8" circular saw. Been thinking it might make a nice addition to the tool bag for remodeling. Its the Versacut.
Anybody tried one? Looks like it might be just big enough to be useful.
Re: Anybody tried a Rockwell Versacut Mini circ saw?
David Barnett
(Message Deleted by Poster)
Ditto
I also did not like the ventilation ports as in use some of them will be blocked and/or exhausting hot air on the grip hand (sweaty palm = loss of grip).
I deemed this a distant "4th" behind the PC 4-1/2" Trim Saw which I've used a lot.
Agree Mark
George Colonel's Workshop-Havertown PA
I was lucky to acquire one of those P+C 4 1/2" trim saws earlier this year. With two extra carbide tipped blades. Its a real hummer.
George
David Barnett
WC more than just woodworking
doug f, san clemente, ca
Though I'm aware of the meanings, I've never seen "prehension" and "haptics" used in the same sentence. It's fun to learn something new every day.
Doug
PaulSV
A number of years ago I bought a rechargeable 3 and 3/8 inch saw made by Ryobi or Bosch, I'm not sure which. (I got that model because it used the same batteries and chargers as a rechargable drill that I already had.) I thought it would be more useful than it turned out to be. Most things can be better cut on a compund miter saw, or on the table saw, or could be cut with hand saws. Very occasionally I have had to cut a straight line on something I didn't want to have to disassemble, like widening a door casing to fit a screen door, and so on. It was handy to use, since I had it, but if I hadn't had it, I would have figured out another way. It would probably be handier for construction, like trim carpentry, than it would be for use in a shop. The one I had was a bit underpowered for cutting 3/4" wood, but I'm sure the new ones are much more powerful.
Grip
I've used any number of barrel-grip tools, from sanders to jig/scroll saws to mini grinders, but I'm not fond of what I call an " 1 handed open grip" configuration where the hand cannot close to the point of thumb connecting with middle and index fingers. You loose a significant amount of control, and it increases (I think) the on-set of hand fatigue as you have to squeeze harder. Small trim saws can be grabby due to their light weight so I prefer a full-grip handle as on the PC or even the little Makita trimmers which have a nice high handle and angle to facilitate applying a bit of down-pressure to keep the blade firmly engaged and on the cut-line.
While I have a big honker of a wormdrive, my favorite and general goto hand saw is the 6" PC Saw Boss for general construction work from sheet goods to 2x.
Mark's got a real good Handle on the subject
;) You've Come to Grips on that one, Mark.
George
Gloves Are Off, Eh?
Last thing we want is for anything to get out of hand. :D
Give these lads a hand for some good puns
Your verbal dexterity is impressive, and not at all sinister.
David Barnett
David Barnett
David Barnett
David Barnett
David Barnett
I looked at the specs, and my favorite part,
Keith Newton
was. "Blade Location Centered " You know, usually they say right or left. I guess this time it must be in the middle of the sole plate. Or maybe they were compelled to note that is where you tighten the bolt holding the blade, rather than just sticking one tooth under the washer, before turning it on.
Re: Grip
Rob Sandow
I do love a couple of barrel grip tools, specifically the Bosch jig saw and Makita angle grinder. I don't think I would like a circular saw with one though. My favorite circular saw continues to be my 15+ year old Dewalt 18V. I have a matching drill, so I can share batteries. I have replaced the batteries 3 times over the years, which does get expensive, but these tools are built to last forever, and unlike the lower cost brands, the mechanical battery interface never changes so you can keep replacing batteries and not have to junk the tool - I have thrown away 2 perfectly good Ryobi drills because the batteries failed and you could not get replacements.
